Need help IDing axle
Mike1919
Fresno
First post but its confusing me. Its a 93 ranger splash with the 4.0. It was my understanding that rangers had the 7.5 except tge 4.0 got the 8.8. The vin decodes to a 4.0, so i know the engine wasn't swapped, however my axle code is 86 which says its an open 7.5. Here's a picture. Thanks in advance.
97RangerXLT
TRS 25th Anniversary
3,966
Fishers, IN
2"
31"
Mike1919
Fresno
I agree its an 8.8 but that axle code is wierd. Heres my sticker.
97RangerXLT
3,966
Fishers, IN
2"
31"
Weeird.
is the actual Axle tag still on the differential cover? I am curious as to the gearing in it.
Sounds like you have a 3:73 open differential, but I would imagine that someone goofed at Ford when they printed your door sticker..
AJ
Mike1919
Fresno
Unfortunately no there is no tag. The previous owner said it has 3.73. But by looking at it, it's definitely an 8.8 right? Where do i go now?
97RangerXLT
3,966
Fishers, IN
2"
31"
yeah, just looking at it I would say 8.8.
As for the gearing, a quick way to check it if you are unsure is to jack up the back end and turn the drive shaft by hand while a buddy watches the wheel. count how many full turns of the drive shaft you make to make the wheel turn one revolution. if you turn it 3 and almost 3/4, you have the 3.73 gears :)
AJ
alwaysFlOoReD
5,122
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
Is the tag on the door, maybe been replaced.
97RangerXLT
3,966
Fishers, IN
2"
31"
looking at the tech library on the axles (see the links in my first reply) the 4.0 always came with an 8.8.
Richard has a good point on the door...
AJ
97RangerXLT
3,966
Fishers, IN
2"
31"
Quick way to check if the door has been replaced with another 93 is the vin on the sticker should match the vin in the window
AJ
Mike1919
Fresno
I'll check the vin in the morning to see if it matches. It does seem like it's supposed to be a 96 axle code though.
Mike1919
Fresno
But even then i ran the vin on the door sticker and it still came out as a 93 ranger 4.0. And if that same sticker says its got a 7.5 behind a 4.0 when ford never did that. Only thing i can think of is someone didn't get enough sleep and mistyped the sticker
Mike1919
Fresno
Okay the vin on the dash matches the vin on the door sticker which matches the vin on the pink slip.
