My New House & Workshop
97RangerXLT
TRS 25th Anniversary
3,981
Fishers, IN
2"
31"
Looks like an awesome job Jim. Glad the trenching wasn't too difficult, and you saved a metric buttload of money doing it yourself.
AJ
97RangerXLT
3,981
Fishers, IN
2"
31"
Oh, and with all this plumbing work you get the "layer the most pipe" award. You should create a banner for it under your user name :p
AJ
Rick W
4,025
Atlanta
Ranger XLT x2
4.0 & 2.9
97 stock, 3” on 87
N/A
Never put off ‘til tomorrow what you can put off indefinitely
You sly devil. It just dawned on me all of this silly “leak” stuff was planned, so you don’t have to fool with lawn sprinklers. Wise beyond his years…
So here’s the big question, I hope I’m not stealing your thunder. When’s the party?
Rick W
4,025
Atlanta
Ranger XLT x2
4.0 & 2.9
97 stock, 3” on 87
N/A
And, afterthought, did you run underground lines for the gas grills or are you going to use propane tanks?
alwaysFlOoReD
5,131
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
Take a close look at the leaking spigots' threads for damage. Make sure its gland? is sealing too.
ericbphoto
Overlander in development
16,706
Wellford, SC
6"
September, in Kentucky.
Rick W
4,025
Atlanta
Ranger XLT x2
4.0 & 2.9
97 stock, 3” on 87
N/A
Jim Oaks
Just some guy with a website
Administrator
Founder / Site Owner
Supporting Vendor
8,801
Nocona, Texas
4.0 / 2.3 Ecoboost
6-inches
33x12.50x15
I cook on charcoal.
sgtsandman
Aircraft Fuel Tank Diver
12,738
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
Roert42
5,015
Kintersville, PA
Ranger XLT
4.0 SOHC
The dope/tape isn’t there to seal the threads. It’s to lubricate the threads, to make it easier to tighten them all the way.
Although, I’m sure it doesn’t not seal.
alwaysFlOoReD
5,131
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
And I've split fittings before... The tape definitely works as lube.
franklin2
1,769
Virginia
I had a plumber tell me that too. I am sure that is a part of it, but there is a reason they put all those solids in pipe dope. Like I said before, if you have a small drip, 90% of the time you come back in the morning it has already stopped or almost stopped. Most water systems have so many minerals and dirt, that along with corrosion from the fitting it will self seal most of the time. Brass and plastic usually take longer to self seal.
Jim Oaks
Administrator
Supporting Vendor
8,801
Nocona, Texas
4.0 / 2.3 Ecoboost
6-inches
33x12.50x15
I spent all day Saturday fixing a hot water line leaking under the slab in my daughters house.
Here you can see water coming out of the pinhole leak. The eater from the hoteater tank was shutoff. This was the water left sitting in the pipes.
For some reason there was a gap in the vapor barrier and some of the pipe had cement on them.
Bad section cut out. Now time to clean up the copper pipe.
A coupling and slip coupling with a piece of PEX in between. I didn't have much room to work, so the PEX piece in the middle is 2.50" long (1.25" + 1.25"), just long enough to engage both Sharbites. I wanted a 0.25" inch gap in the middle but i got tiredof trying to wire wheel and sand all of the cent and crap off the pipe, and the closer it got to the edge of this hole the harder it was to work.
I spent 12-hours removing the ceramic tile, cutting, hammer and chiseling through that tough ass concrete, going to Lowes for parts, cutting the pipe, cleaning the pipe, smoothing it with 600 grip paper, getting the fittings on, and then getting the slip coupling to slide into the other joint. This copper pipe was slightly bent so the coupling didnt slide easily.
Went back over today, made sure it wasn't leaking, wrapped it with sharbite tape, filled the dirt/sand back in, put down some plastic, and then covered that with concrete.
They have left over floor tiles. My son-in-law will reinstall the tile.
It was going to cost them thousands to have a plumber fix this. Doing it ourselves cost them about $110.
On a side note, I got electrocuted twice before realizing the cord on my drill finally worn to the point there was a small section of bare wire exposed.
I wasn't even using it. I just touched the cord while I was on the floor working. Wasn't sure what shocked me the 1st time.
I hate that feeling.
I hate plumbing. I've done to much of it lately.
Rick W
4,025
Atlanta
Ranger XLT x2
4.0 & 2.9
97 stock, 3” on 87
N/A
I love it, satisfaction of an impossible job. Well done.
How on earth did you ever find where it was leaking?
97RangerXLT
3,981
Fishers, IN
2"
31"
how did you pinpoint the leak under the slab? infrared heat detector?
AJ
