My first tow pig
Mightyfordranger
158
Ohio
2.9
3in
Clean your room before you criticise the world.
Don't have any pics right now but it's a 02 Chevy 2500 with a 6L gas it needs a lot of things I just put a starter in it and it needs new brake lines and the whole deal it was sitting for years in my aunts yard she just gave it to me lol I'll get pics here soon
sent while bored
Doofy
7
Alaska
Shit Happens...Then You Die.
Two Pigs are nice especially free ones. Tow Pig!
Andy D
10
Marshfield MA
The Rat
4.0 OHV
to prevent Found On the Road Dead, Fix Or Repair Daily
Replacing the brake lines just because or has one let go? Are you gonna use that copper line? The hoses are probably OK. If you can get the bleeders free you can save the calipers. what do the pads look like? Good luck
Captain Ledd
39
Michigan
302, 2.3
If you're not making mistakes, you're not learning.
Free is a hard price to beat.
Hopefully it doesn't take too much to get it up to snuff. It helps when your initial investment is small lol.
swynx
9
lewiston idaho
Mazda
make sure to keep an eye on the oil pressure.
alot of my friends are big into those LS engines, and everyone i have seen died has been from a faulty oil pump. im told its one of there faults
Mightyfordranger
158
Ohio
2.9
3in
Thanks for the oil pump info actually my uncle had a 07 6L that went to pot from a bad oil pump. And as for the lines I haven't even hit the brake pedal once cause it's so crusty under there I haven't found any frame holes but I was spittin rust out while putting the starter in it even had it in my armpit lol
sent while bored
Mightyfordranger
158
Ohio
2.9
3in
The calipers look like blob of rust and the heads of the banjo bolts look really bad
sent while bored
