- Jul 12, 2009
- 0
- Tucson, AZ
- Ford
- Engine Size
- Supercharged 5.0
I am using the stock steering box with a heavy duty drop pitman arm (not sure of the make though. Got it in a trade). Pitman arm has been drilled out for a 5/8" bolt. The heim joint is 3/4" on the threaded side and the eye is also 3/4" but I am using a 3/4" to 5/8" high misalignment spacer since most of the travel is done on the pitman arm side.Sweet rig! Couple questions about your sas: What steering box pitman arm combo? Stock trac bar mount at the axle or fabbed? What heim did you use at the pitman arm, and is it just drilled and bolted conventionally?
On the axle side for a trac bar bracket i used ballistics fabrication's offset bracket for that. Lucky me they are right here in Tucson
