Motor Identification
Redleg68
Law Enforcement
4
Barren County, KY
I have a 302 motor I am trying to get info on. I've searched the internet and can't seem to find codes that are located where mine are at. Hoping someone on here can help me figure out what I've got.
CorbinsRanger
114
Saskatchewan
FX4
31x10.5x15
Saskatchewan...hard to spell...easy to draw
Looks like E7TE casting number comes out to an 1987, 302 Windsor small-block, 2-bolt mains
CorbinsRanger
114
Saskatchewan
FX4
31x10.5x15
E is the 80's.....sigh.......7 is the year.....T is for Truck.....E is for Engine.
rusty ol ranger
2.9 Mafia-Don
7,800
Michigan
177 CID
87 wasnt a bad year for 302s. I think they made like 185hp and 270ish ftlbs.
19Walt93
4,517
Canaan,NH
351
3"
235/55R16
E7TE identifies a casting introduced in 1987, it doesn't mean it's an 87 engine. The only 302's with more than 2 main cap bolts was the Boss 302, Chevy often used 4 bolt mains in a failed attempt to keep their grenades together. The heads used on 5.0 Mustangs from 1987 through 1995 were marked E7TE and they're decent heads. That's actually what I used on my 351. If it was a Mustang engine, it would have made 225 hp but you can easily do better.
rusty ol ranger
2.9 Mafia-Don
7,800
Michigan
177 CID
In theory it could be an 87-93 correct?
Redleg68
Law Enforcement
4
Barren County, KY
So what does the OF12 tag indicate?
Or as Corbinsranger would ask,
O, sigh, F, sigh.... 12..... Sigh.... Indicate :unsure:
superj
2,765
corpus christi, texas
ranger edge
none
none
235s
drives a stick shift ranger
i think he was sighing at the low power 80s, ha ha ha
CorbinsRanger
114
Saskatchewan
FX4
31x10.5x15
It's a truck engine. And according to Ford E is eighties and it was cast in 87. If it were any other year it would be 4 or 6 or 9 etc.
19Walt93
4,517
Canaan,NH
351
3"
235/55R16
An E7 casting number identifies the first year of that block, the casting number isn't the date code, that's in a different spot.
19Walt93
4,517
Canaan,NH
351
3"
235/55R16
rusty ol ranger
2.9 Mafia-Don
7,800
Michigan
177 CID
Possibly 87-95 in a Mustang, 87-96 in a truck or as late as 01 in an Explorer when the 302 went away.
Didnt the blocks change in 94 with the switch to rollers?
pjtoledo
3,050
Toledo Ohio
Fords
3.0 2.3
June 12 1990
19Walt93
4,517
Canaan,NH
351
3"
235/55R16
Mustangs got rollers in 85. I suspect Ford used the roller block with flat tappet lifters until they decided to convert trucks to rollers, rather than cast 2 different 302 blocks or they used up existing stock in trucks. They don't spend money without reason. When compression dropped for the 73 model year, 302's got an additional .023" of deck height through the 76 model year, I had heard they did that because they had a warehouse full of existing pistons.
