briansz
- Sep 23, 2007
- 1
- Ford
Those of you who have been on TRS awhile are probably a little familiar with my saga to get my truck back to daily driver territory. It's been around 4 years now. The 2.3t is waiting in the wings, and I've successfully bartered for some garage space to do the swap in the spring, but in the meantime I want to run the truck if I can, especially without the factory 1bbl.
Picked up a late 70's 2300 from a Mustang II today for $75, complete minus alternator and exhaust manifold. Supposedly rebuilt within 7500 miles and then the car was hit in the rear and totalled.
Looking forward to being able to use some of my 2bbl Autolites, Holley 5200s, or 4bbl Holley 390 with the oval-port head on this motor - finally! I could never work those out to be used easily with my existing built round-port head, at least not with a distributor.
So questions. Other then swapping the pan and pickup from front sump to rear and blocking off the fuel pump hole (I have electric) are there any differences I should be aware of? I'm installing in an '83 2wd with TK4 that will be upgraded to M50D shortly.
How about the flywheel? I have one from an '88 Ranger along with that clutch (think M50D splines may differ, however) that I can use. Several starters laying around too. One from this engine-donor Mustang, one from the '87TC that donated my 2.3t, and of course the stocker in the truck. Are they all compatible?
Thanks for any info, may get this thing back on the road yet, and for not much cash.
Brian
Brian
