Misfire on 45 and 6?
Toddster385
Muskoka, Ontario, Canada
Ford explorer s
Installed a used 4 litre in my 09 sport trac, misfiring bad on 5and 6,4 also but not as bad, could it be a sensor because it is all on the same side, please help,
Could be the plug wires are on wrong, could be injector/wiring issues, could be a bad timing chain on that side,
8,373
Look at your coil pack wiring, the coil pack only has 3 coils inside, NOT 6
[3 4]
[2 6]
[1 5]
These are the match sets of spark plugs that FIRE at the same time, 3/4, 2/6, 1/5
The 5 6 4 side often gets miswired, if its 4 5 6 then all 3 would misfire
Follow each wire to its cylinder on drivers side
Toddster385
Ford explorer s
Awsome thank you for the plug chart, 5 and 6 were backwards, still misfiring but numbers are lower, will this reset after a certain mileage or time?
Roert42
5,028
Kintersville, PA
Ranger XLT
4.0 SOHC
What numbers are lower?
also a code for misfire will not reset by itself.
Toddster385
Ford explorer s
Misfire numbers, it is still misfiring not as many times, has a way more power and rpms, so if I reset the codes it shouldn't come back
Dirtman
13,329
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
Well if its still misfiring that's still bad... the proper number of misfires is ZERO.
8,373
Find out which one(s) are misfiring, code P030X, "X" being the cylinder number that's misfiring
Pull that spark plug and see what it looks like, "new" means NEVER EVER tested, it no longer means "it works"
Same for wires and coil pack
Because the a coil fires TWO cylinders at the same time, you CAN swap those two wires around
i.e.
3 4
6 2
1 5
works exactly the same as
3 4
2 6
1 5
But if misfire MOVES to #2 from #6 then you would know the "new" coil pack is bad
So find out which cylinders are misfiring, FIRST, then go from there
Toddster385
Ford explorer s
Ok thank you Ron, we had the misfire on 5 and 6, sometimes 4,we had wires five and six backwards and it ran better but still misfiring and I saw a misfire on 1,but it ran better, it was only down the street, so just wondering if after doing the test that you are suggesting will it get better as it drive it, or could it now be a fuel problem
8,373
Fuel is a long shot when there is a misfire
Spark and/or compression are usual cause
Since original engine had misfires it could be what adsm08 said, the computer is not opening certain injectors
UNLESS....................you know vehicle/engine has been sitting over a year with fuel in the injectors, then they CAN BE clogged up
Did the "used" engine come with injectors or did you swap yours over?
You can take off the big air hose from intake, start engine then spray Fuel into the intake, if it stops misfiring then could be injector issue
Toddster385
Ford explorer s
The used engine came with injectors, we have cleaned and changed and swapped injectors, our snap on diagnostic computer says no fault in any injectors, I just took it for a small drive to the end of the road and it felt good like it was running perfectly but it still registered misfiring. But I will try the fuel spray directly into the injectors tomorrow morning, and thanks for the help everyone, you guys are awsome. Thanks
