mountaineergreen
- Apr 30, 2008
- 0
- Age
- 40
- Ford
- Engine Size
- 3.0
I'm a believer in UDP's- I know they helped my Ranger.
Welcome Visitor! Please take a few seconds and Register for our forum. Even if you don't want to post, you can still 'Like' and react to posts.
Simple? Yes.The theory of why UDP's see gains is a pretty simple concept. I am baffled why some people cannot understand that.
Rocket there are pluses and minuses to changes from stock. For my OWN use changing the pulley would be a minus...as I drive slowly and in stop and go traffic for the most part. Having a UDP would undoubtedly give me less lectric out of the alternator and less coolant flow in the summer heat. Not to mention less freon in that same heat.
Now if I were keeping the R's at 3,000 and above I could use a UDP without fear.
Lots of stuff is available as a bolt on for our vehicles that have a purpose.. however most of us will never quite meet the purposes criteria. We blindly purchase these items with never a thought as to what the purpose of the item is.
In my case as the engine began to heat up the thermostat would open wider and the coolant pump would have to work harder to pump more coolant to keep the temp where it should be.. So while I was grinning at the fuel I was saving from my install the coolant pump would be working harder eating up my savings.. All the while I wouldn't have a clue as to what was going on in there..
Then as the temp of the coolant began to build up in the radiator the clutch-fan would start using more power to cool the radiator...and there would go some more of my fuel!
All the while I was grinning I prolly would be using MORE fuel, caused by what I still keep thinking was a good idea.
Big JIm
Corrected, this reads:With that said, you still cannot argue with the power results in the cases where UDP's are offered and able to function in a vehicle with minimal side affects.
And whatever UDP's do "Gain" it is mostly at HIGHER rpm than "cruising"
And what's left is WHILE accelerating, what remains is tiny indeed and mostly because the people doing the testing want to believe.
I'm not saying you aren't trying to be objective in your testing
I'm saying that you are incapable of being truely objective.
and generally we all have difficulty being objective.
A true "objective" test would be having a driver other than the vehicle's
drive it both with and without UDP's and not informing them of the switch.
It is intuative that spinning the engine accessories more slowly
would reduce drag, but as I outlined above, considering all the
factors reveals that any possible effect can only be a small
fraction of what the optimistic buyers of those things want to believe.
And it's in the sellers interest to make money.
The vehicle manufacturers are scrambling and grasping at straws to save every fraction to meet CAFE and yet many believe if they could spin shit more slowly to save gas they wouldn't try it....
Anyone remember VAP/S?
Yeah, spinning your alternator more slowly might saye you something
but probably only 10% as much as folding in your side mounted Rearview mirrors above 45mph.
Or taking the crossbars off the rooftop road rack on your explorer or bronco2.
AD
AD
You're screwing with REGULATED systems. It will compensate away everything, until you max it out. Once you max out the regulation, you have a substantially lower performing system than what you had to start with.
AD,
Regardless if it is power under the curve or at peak it is still power gained. Obviously I would rather have a 5 hp average under the curve gain than a 10 hp peak only gain any day of the week. The more usable power the better. Still, power gained at peak does count for something. I believe your previous post that I quoted in my last post was inaccurate and much too general a statement.
By what personal testing or firsthand knowledge are you able to come to the conclusion to back the statements you have made here in your last two posts? If I am understanding them correctly you are more or less saying that UDP's do not net any real results??? Not only that but it also seems that you go on to say that they "cannot" net any positive power results due to the circumstances you outlined in your first post I replied to??? As a person who does one hell of allot of vehicular power modification I would have to strongly disagree if that is your position.
As a performance business owner I always do allot of testing to see gains in vehicle from various power modifications. I rarely trust another persons results because I never really know how scientific their approach was to getting their data. In my testing it is as simple as the UDP's went on and power increased. The reason that happened was because there was less parasitic loss from the other front accessories on the engine. There was power under the curve and also at peak as well. I trust my findings, which include understanding of both theory AND application versus what seems to be just theory alone. While there are power mods that are sometimes hyped a little too often by salesmen only caring about making a buck, I can say that in allot of cases UDP's are not one of them. Not all vehicles will gain the same amount of power from UDP's or any mods for that matter. You may only gain 8rwhp and 9 rwtq on a modular 4.6 from a Mustang GT but when you do UDP's on a 4.2 V6 you only gain 3rwhp before running into charging or cooling issues. Regardless of how much power happens to be gained in a given application the theory behind why and how UDP's can achieve power gains is solid.
I do not mean any disrespect by anything said in this post. I am just calling it the way I am seeing it here.
I don't think you are being disrespectful, but I do think you are looking at the problem with too much focus, tunnel vision infact.
So while you may be calling things the way you see them I'm gonna keep telling you you need new glasses.
At the risk of further wasting my time...
IF I accept the arguement that the pullies save you 5%
at the power peak (and quite bluntly I don't) that does
NOT equate to saving 5% at cruising rpm.
at say 5000rpm the savings MIGHT be 5% but at 3000rpm it will
be at best 2.2%, and could easily be only HALF that...
That's the part you aren't getting, they don't Save "x" horsepower
they save a percentage, but that percentage varies depending on where in the rpm range you are looking
SELF REGULATING SYSTEMS tend to compensate for your
phucking around with them.
As I said above if you spin the alternator more slowly, by ANY degree the voltage regulator will simply turn up the field current as much as is necissary to maintain voltage, it can easily DOUBLE the field current while attempting to do this and since the alternator operates less efficiently at the lower rpm caused by your underdrive pullies the V-reg will turn up the field current even farther.
So in all likelihood from the standpoint of the self-regulating alternator alone you can easily wind up with a net loss.
Infact it's likiely that you could see a power gain by spinning the
alternator FASTER by installing a smaller pulley on it....
Because the alternator becomes more efficient as it's spun faster, thus field strength would be reduced...
What MAKG and I are trying to tell you is that you are basing your ASSumptions on exagerations if not outright LIES of the makers of
those pullies.
Manufacturers who make them because someone like YOU is willing to buy them.
Underdrive pullies were originally made by race teams, not to "Save power" by spinning the accessories more slowly, but to spin the accessories more slowly in race conditions to avoid blowing the accessories because they were spinning them
sometimes twice the speed they were designed for!
If you are getting better mileage with UDP's it is due to unconcious
subjective differences in your operation.
you NEED to perform a test that is not subject to driver input
concious or otherwise.
and even the best laid plans... it's likely that if you were to drive across Nebraska on cruise control both with and without the pullies that there's be some other difference that would queer your results one way or the other
(temp, traffic wind speed or direction etc)
In any even the maximum change your pullies could generate WITHOUT self regulating systems negating the effect is ~0.4mpg.
So I'll bluntly call bullshit on any greater claims right here and now.
