max front driveshaft u-joint angle
nooch450
4
New Jersey
4.0 OHV
How far can I push the front driveshaft u-joint angle?
Would the answer be the Same for the u-joint for the axle shaft for the passenger Axle beam?
4x4junkie
585
So. Calif (SFV)
Bronco II
2.9L V6
35x12.50R15
Front driveshaft (pinion) angle isn't overly important... Up to maybe 10° I don't see causing an issue.
If you're concerned about front caster angle vs. the pinion angle, focus on your caster. Pinion angle comes last (if at all).
nooch450
4
New Jersey
4.0 OHV
Thanks :icon_thumby: I should have more pics of the build soon :icon_welder:
