Manual Transmission won't go into gear
Medic_
LasVegas, NV
Ford ranger
It's just 1st and 2nd that I have a problem with since I do frequent driving in the city.
superj
2,674
corpus christi, texas
ranger edge
none
none
235s
drives a stick shift ranger
thats the part that makes it weird. i know on brakes what causes that with vacuum assist leaking but for your truck, the only temp related issue with the transmission would be if you are low on fluid but that would not make it hard to shift into gears unless something is locking up. and you would know that with other symptoms.
you could check the transmission fluid and make sure its up. if that fixes the problem, let us know
superj
2,674
ranger edge
none
none
235s
you should have two plugs on the side of hte transmission, one above hte other. the lower is the drain. usually, to check fluid in standard transmissions, you take out the top plug and see if the fluid is right at the edge of hte plug with your finger tip. if its not, than you add fluid. that is usually though so make sure and google how to check it for your transmission
Medic_
LasVegas, NV
Ford ranger
At first I was over filled but I took that fluid out by just taking out the fill hole plug. It was probably like half a water bottle more than it should've been.
superj
2,674
ranger edge
none
none
235s
so than it has to be something in the hydraulic side of your system. does any of it run very close to the exhaust? maybe its getting warmed by exhaust and something weird is happening? i don't know if it could but i suppose its possible.
superj
2,674
ranger edge
none
none
235s
hopefully one of the other guys has an idea and can add something as they log in later
Medic_
LasVegas, NV
Ford ranger
Yeah thats what I noticed that it's next to the exhaust but how would that be possible if the old system wasn't having that problem? Should I use the exhaust wrap? Or a heat shield?
superj
2,674
ranger edge
none
none
235s
you can put something around the clutch line for now, to test it out. wrap it in aluminum foil to see if it helps. that was an old school test method on carbureted vehicles to see if they were getting vapor locked from the engine heat on the fuel line. my karmann ghia always had aluminum foil on the fuel lines to help fight heating hte lines up.
Medic_
LasVegas, NV
Ford ranger
It's got the aluminum wrap on the master cylinder line already.
