Making a kill switch
kevinbmx77
Would adding a sitch on the wires going to the inertia switch work as a kill switch? Just cutting power to the fuel pump? Or will it cause problems
Sent from my SM-G920P using Tapatalk
SenorNoob
587
Middle Tennessee
1.5" Front + 4" Rear
245-70-R16
Well, it'll lean out before it dies. I doubt it'd cause damage since it would happen so fast, but there are better ways.
I'd tie into the main wire from the ignition switch.
8,372
Inertia switch is a 30amp circuit, short would ruin your whole day :)
If you want to do it use a relay to cut power, relay's coil can be powered by the fuel pump power, and switch just controls the coils ground to close relay, or leave it open(killed)
You already have similar in the Fuel pump relay, it is in the engine fuse box, it is controlled by the computer using a Ground, you could put a switch on that wire without a worry, and it would give you the same results.
kevinbmx77
So the ground wire of the relay is the wire i want to put the switch on?
8,372
Yes, whether you add your own relay or use existing fuel pump relay, it is best to use the ground wire as the trigger(on/off).
Benefit is that wiring to a switch has no shorting potential and it is low amps.
Most automotive wiring is done this way if possible and practical.
If you want to shut her down in a hurry without the key I'd put your switch on the power line to the coil. Killing fuel like that isn't good for the injectors. That's why the coil, fuel pump, injectors and PCM all get power from the same place, shut off one and shut off all.
