just started a 3/4 drop
marz68
sun valley ca
2.9
Hey 83bagged and slammedxonair, I ask you guys cause I notice that your trucks are layed out on bags. Will I have bump steer problems if so will I need tie rod end spacers?
Thanks in advance.
83bagged
January 2010 STOTM Winner
MTOTM Winner
LOUISIANA
302
no, not that i know of
what size tires are those? and how tall are they? i called my local JY, and they have a full 4 set for $80!!!! o yeah, gettin tomorrow son! WOOT WOOT
marz68
sun valley ca
2.9
ok thanks!
I'll measure the tires tomorrow and please post some pics of your truck when you get the new rims, can't wait.
83bagged
MTOTM Winner
LOUISIANA
302
lol, o problem bro! thatll be a little while though, gotta drop my new GT40 heads on the 302 and get her runnin before she deserves the new shoes! gonna spray em white to match also
yea, try and measure the width and height. and the tire size on the side, thanks bro!
slammedxonair
Vermilion, OH
91 and 00
bump steer is caused form messing with the factory suspension and steering geometry, mainly the pivot points.
TS6034
September 2009 STOM Winner
MTOTM Winner
Northern Michigan
306
You should be able to adjust the stock tie rods to correct the toe issue. I'm not familiar with "tie rod extenders".
Your truck is looking good.
WhiteLX
So Cal
2.9L
How did you lower the rear?
I used I-beams up front and a drop leaf in the back and it looked to be able the same height. Problem with the rear is it was on the bump stops, just a little too low for my taste. I ended up putting the stock leafs back in, flipped the shackles, and removed the overload spring. The rear sits a little higher than the front so it has a little rake. I'd like for it to be a touch lower to make it level, but I can live with it.
I'm using 17x8 bullits with 245/45R17s. I did have to run a 5/16 spacer up front and pull the fenders out slightly to clear.
marz68
sun valley ca
2.9
Thats gona look cool with the white 17's.
So heres what I got, the tires are 25" tall they are 235-45-17.
I drove my truck to test drive it and when I went in to a drive way the front rubbed on the fender so I dont know if you want to go with a more narrow tire since your way lower than me. You can also un tuck them since you do have air bags and I don't!:bawling: Maybe roding my fenders will take care of that problem for me?
marz68
sun valley ca
2.9
The rear is just a flip kit and mine also sits on the bump stop but I will be notching and baggin the rear cause I like it low!:icon_thumby:
marz68
sun valley ca
2.9
The reason I sak is because the extenders I talk about are offered for the 68 f100 dropped ibeams.
83bagged
MTOTM Winner
LOUISIANA
302
awesome man... thats the same height as my stock tire, thats PERFECT! now to test them and make sure they will tuck and untuck with no rubbing
slammedxonair
Vermilion, OH
91 and 00
I think I have seen something for them before they drop the steering linkage down or soemthing, which still changes the geometry. I think the steering on them is also behind the ibeams as well.
marz68
sun valley ca
2.9
Thanks for all you help guys.
Here it is sitting on the bump stops in the rear.
Here it is ready for the mini notch.
marz68
sun valley ca
2.9
Here are my two rangers.
marz68
sun valley ca
2.9
Anybody know on a extra cab ranger how much the carrier bearing needs to be moved when doing a flip kit?
I know they sell the spacer but i would rather make it at home.
