so here we are more than a year later and I've put about 9,000 unpleasant miles on this thing.
It's always been turd slow, but a several months ago it started bucking, got even slower, and seems to lose power when I pass a certain threshold of throttle. Replaced the fuel filter, again, and checked fuel pressure. Key on engine off, the pressure would build and then fall back off almost immediately. Coupled with taking a solid 5-10 seconds of cranking to start (even more when hot) and I thought injectors were a reasonable diagnosis.
So I replaced those today and it made no difference whatsoever in the way it ran. I haven't driven it enough to know if it starts easier yet. So it's possible I fixed the starting problem but it's still miserable to drive.
Seriously, it can't keep up with a beat up U-Haul truck pulling an SUV up a hill. I tried a few weeks ago.
So now that I've replaced plugs, wires, distributor cap and rotor, injectors, swapped coil, MAP and TPS with a good running truck, no vacuum leaks, clean air filter, no CEL, I'm basically left with no option but mechanical problems. Guess a compression test is in my future. I'm wanting to get a different vehicle, like a 2.3T Mustang SVO but I can't see getting the amount of money I need out of this thing until this issue is fixed. I may end up having to drop in a JY 2.9 just to be able to sell it and I hate the idea of putting that much work into something I'm trying to rid myself of.
Last week the AC blower just up and quit for a few minutes, then came back on, and has done that twice more now so I expect a permanent failure is only a matter of time.
Yesterday I put a new muffler on it because it had one of those $30 Raptor mufflers from O-reilly and the droning around 2800RPM was unbearable.
Then, this morning on the way home from work (night shift) I started hearing a clunking noise in the front end over bumps. Steering linkage is tight so I guess I must have a loose ball joint or wheel bearing.
It never ends with this thing.
