Lift
- Jan 12, 2010
- 0
- Washington
- Ford Ranger
- Engine Size
- 302
Welcome Visitor! Please take a few seconds and Register for our forum. Even if you don't want to post, you can still 'Like' and react to posts.
First time I hear about a 4.0 using a barometric pressure sensor... I thought that was calculated by the MAF sensor output? Someone else will have to chip in on this one.i removed it and cleaned it. The engine still bogged and the idle went down slightly. Im going to replace it. If that doesnt fix this problem can not having a barometric pressure sensor do it? i dont even have one. When the previous owner did a motor swap he forgot to put it in.
A while ago there was this guy that had the same over-revving problem and he went replacing everything around the MAF and cleaning the thing like a thousand times until he replaced it. Problem solved... Do a little search in the forum you'll find it in there about a year ago.I didnt replace it i cleaned it. And it didnt do crap. When i went to pullapart i got the wrong unit so i didnt bother.
I would recommend a brand new IAC since it's a moving part that builds carbon deposits, which are the ones that makes it get stuck with time... That's my .02, You might end up where you started with a junk yard unit.oh you saw my tachometer ha? i had a swap at hundred thousand miles that motor in it now has 80 thousand on it. And thanks for the advace i will pick up a junkyard one this weekend. Ill get a mafs and a iacm.
