i think i broke something!
B2Guy
Lafollette, TN
2.9
today a few of my friends and i all jumped in our vehicles and went wheelin. everything was going fine, it was a great day for wheelin. we were all at this rough real rocky spot and i was flexed out on the front pass side and my coil popped out... no problem, i got it back in after about 15 minutes of working on it... start going again and i notice this horrible grinding noise.
i pulled my pass side front wheel off and checked everything. its not a busted hub, started pulling my outer wheel bearings off and they're fine (before i started i noticed alot of play in the axle shaft when trying to move it around.) checked the u-joint and it looked fine... nothing rubbing on the rotor... any other suggestions?
Something may be damaged in the diff.
B2Guy
Lafollette, TN
2.9
id does it worse when i turn pass side going down the rd. maybe the inner axle shaft bearing?
country0001
14
Stillwater, OK
Ford,Ford
4.0,5.0
Did you check the other side?
b2rich
Lake Oswego, OR
whats an engine?
B2Guy
Lafollette, TN
2.9
i think the c clip is fine. i havent checked it yet. will check it tomorrow. i didnt check the other side either only cause i was still on the trail and just wanted to get out of there after that point.
88_Eddie
155
Raleigh, NC
2.9L, 4.0L
are you still running a D28?
B2Guy
Lafollette, TN
2.9
still have the d28 with 3.73 gears manual hubs. all stock... and yea, i know thats my main problem. still having the d28
disciplerocks
July 2011 OTOTM Winner
53
Evansville, IN
Does 4wd still work?
88_Eddie
155
Raleigh, NC
2.9L, 4.0L
lol, yeah, that's what i was gonna say....get rid of it
B2Guy
Lafollette, TN
2.9
yea 4wd still works and my hubs work fine.
and yea i do need to get rid of it but thats not an option right now money wise.
B2Guy
Lafollette, TN
2.9
ill keep this post updated with my findings tomorrow when im working on the pos d28.
anyone have a eb d44 they would like to donate? didnt think so...
disciplerocks
53
Evansville, IN
I have a complete dana 28 sitting in the yard taking up space if you want it. Needs pass. side axle shaft.
88_Eddie
155
Raleigh, NC
2.9L, 4.0L
yeah, i'll have a complete D28 as soon as i get my d35 in.....if you need a new pig, mine has 3.73's
Junk Collector
Truck of Month
4,802
Rapid City SD
Could it be the slip joint on the passenger side shaft?
