HUB Replacement Help
killswitch21
HTX
Ford, Honda
2.9L
1990 Ford Ranger 4x4 2.9L with Dana 35 Front Axle on 31s.
I was replacing the front brakes over the weekend and when I was pulling the locking hubs apart I noticed the Plastic Cam on the Drivers Side was Busted.(probably would explain the clicking in 4x4) Also the splined thrust washer was significantly bent.
Anyways it appears I cant buy just the cam for it without buying a whole new HUB, So I guess I don't have much of a choice other than to upgrade to the manual locking Hubs. However I'm supposed to reuse that Splined thrust washer with the swap, any idea where I can find a new one at?
-So I have found Warn P/N 29071 for about $223, or the beefier Warn P/N 37780 for $262. Is it worth the extra $40 for the beefier hubs?
-The only other thing I will need to install is the 32720 conversion kit right? which is really just 2 sets of 28068X in a box that costs twice as much right?
Thanks in advance.
killswitch21
HTX
Ford, Honda
2.9L
So I actually found a used set of 29071 Warn Locking hubs that includes the 32720 Conversion kit for $150. Considering the cheapest I could find new was piecing it together on Ebay for $232, or $278 from summit. Do Yall think its worth it to buy the used set to save $82-$128, or should I run like hell from a used set of hubs? They seem to be in good condition based on the Pictures, and the seller claims both dials turn easily and that locking mechanisms work.
That is of course assuming its not absolutely worth the $320 it would cost for the beefier Warn 37780 Jeep hubs and spindle nut conversion
Either way, I still need to find a replacement Splined Washer for the hub. (first piece off after the C-Clip) Any suggestions on where to find it at?
4x4junkie
584
So. Calif (SFV)
2.9L V6
35x12.50R15
I suspect the only place you will find those parts (washer + cam) is in a wrecking yard (1997 was the last year vehicle those (or similar) parts were OEM).
From my experience though, they generally are easy to find in good condition (certainly they are plentiful in the yards around me anyway).
As for standard hubs vs the Jeep hubs, it will depend on what your future plans are for the truck... If you don't intend to put larger tires (33"+) and a differential locker on it, then the standard hubs should do fine.
I have the #37780 Jeep hubs on mine, but also 35x12.50 tires and a locker up front.
killswitch21
HTX
Ford, Honda
2.9L
Thanks, I'll check the junkyard this weekend. I'm probably going to stick to 31's for tires, though I would like to get a locker eventually, so I'm not sure if I should opt for the #37780 Jeep hubs because of the eventual locker or if the #29071 will be fine with the locker because it only has 31s
4x4junkie
584
So. Calif (SFV)
2.9L V6
35x12.50R15
Probably will depend on your driving style then...
If you're a fairly conservative driver (you're not tempted to assault offroad obstacles with lots of throttle) or you just need to get to a local hunting or camping spot (mild-moderate forest roads, etc.), I think the standard hubs would still be fine, locked + 31s.
If rock crawling, fast mud bogging, etc. is in the cards though, then it certainly can't hurt to get the better hubs. There's no downside to them other than a little more cost. But it's your call.
killswitch21
HTX
Ford, Honda
2.9L
Thanks for all your help!
And for anyone else who ends up here, I believe the splined washer that holds the hub guts to the axle has a P/N of F57Z-3B458-A
Will
514
Gnaw Bone, Indiana
Toyota
I hadn't been using that splined washer and clip. I guess it's better to have it in there, but I never did.
Definitely want to spring for the better lockouts if you are going offroad. Don't need them just for regular driving, but anytime you are needing to use a lot of power, POP! and the top of the hat is gone and you're screwed.
