How to disconnect the 4r44e connector??
meck
Madison County, KY
1994 extended c
What's the secret to disconnecting the main connector on the 4r44e transmission. I want to test some circuits but am having trouble seeing how to get the connector separated. I don't want to break it. Thanks.
Pull the blue cover off, there is a 10mm bolt holding it together.
Transman304
43
Morgantown WV
Chrysler PT
2.4
If you can’t fix it with a hammer, you have an electrical problem
No bolt on the E model. It has a metal bail that needs to be unlocked and then pull straight out on connector. If this is the connector you are referring too.
meck
Madison County, KY
1994 extended c
Thanks for your answers nad, yes, that is the right connector. I haven't been back under it this morning, but I'm hoping it has the bolt, not the metal bail. Is the bail hard to remove? There's not a lot of room to work.
