how do i flip my 1994 ford rangers axle
94rangerdude
streetsboro
2.3 4 cylinder
i have a 1994 ford ranger reg. cab long bed 2wd. i have fiberglass leaf springs and i was wondering how i flip the axle to on top of the springs to give it a little lower of a drop...? any suggestions??? and pics would help a great deal too.
thanks, brandon
scotts90ranger
4,426
Dayton Oregon
2.3 Turbo
you would have to weld on a new spring perch, that's about it, but you do realize that is going to drop it like 4", right?
if you only want a little bit lower you can flip the rear spring hangers so the shackle works the other way, I think there's 6 rivits to grind off to do this, replace them with 1/2" bolts, I believe you have to swap the hangers side to side and drill some new holes, but is otherwise pretty straight forward. if I remember right this gives about 2" of drop and a little bit better ride
Casper98
August 2012 STOTM Winner
MTOTM Winner
8
Oregon
Buy a flip kit and some lift shackles, or flip your hangers like stated above
Hazmat Ranger
May 2009 STOTM
MTOTM Winner
40
North Texas
4.7
You do NOT need new perches welded on. A DJM flip kit has the U Shaped locators for the top of the spring and lines it up on the under side of the original perch as you can see here:
So no perch welding necessary . . . there is more information in the Tech Library about flipping the rear axle. If you have any troubles or get stuck - check back. My write up is in the current TRS Magazine . . .
94rangerdude
streetsboro
2.3 4 cylinder
thanks you guys i really appreciate the help, im gonna flip it and ill have the pics up when i get it done.
thanks,
brandon
Insanejughead
33
Missouri
'94, '86
2.3T
Since you have a fiberglass spring, it's not going to lower it as much as a set of steel springs would.
I want to see pics too when you're done. God bless and have fun!
PFC Laird
UT
352FE
here's a better view of what hazmat's got
and my 94 short bed with 3/4 djm drop kit
