Mark_88
- Aug 11, 2007
- 240
- Age
- 68
- Ontario, Canada
- Dordge
- Engine Size
- 3.3 Fuel Injected
- My credo
- Love Thy Neighbor
Good afternoon John...too bad you aren't near someone with a NA running engine for sale or trade etc....instead of taking that apart and interrupting the seating rings..etc...the bore is most likely standard...you could take a bearing cap off and tell what bearing you have.,
All Turbo blocks are large journal crank, (if the block has has a turbo oil drain hole)...
if someone would want the pistons it would be best to leave them connected to rods etc...those pistons are hard to find and are no longer available from FORD...There are aftermarket non-forged dished pistons out there so finding out what you have would be good...clean a top of the piston w wd40 and see if it has any markings...
Anyway...those heads (actual turbo'ed) are rare uncracked, so if it's all been done..it's kewl...and it would be great used on flat top pistons..
i wouldn't buy a kit for that motor,,I would piece together what you need...
but first decide what you're going to do for pistons and rods..
to run a carb..or even EFI, you will want flat tops though..
that may be a good engine to use as a turbo'ed install for someone..
That's what I was thinking...it would nice to find someone who wants a turbo block and swap it out for another 2.3/2.5...and too bad it isn't closer to me because I'd trade out my bottom end for that turbo in a flash...
But, anyway, it was a good find and if you can use it then go for it...plug up the oil drain and you're good to go...unless you want to use the oil drain....all 2.3 heads have the hole at the back (at least mine did from the Mustang) and I didn't know what it was till someone pointed it out to me...
