how can i make my leaf-springs softer?
cammeddrz
23
Ford/chevy
efi 350vortec
i have a complete 1976 chevy full size frame under my bronco ii, and needless to say the springs are hard as hell. how can i soften my leaf springs?
bduke23
Saskatoon, Sk
Take out a leaf maybe? Or some people swap chevy leaf packs into their rbv's, perhaps you can swap them out and replace with actual B2 springs?
cammeddrz
23
Ford/chevy
efi 350vortec
i have leaf springs up front too
LittleBigFoot
5
Denver Colorado
Mostly Ford.
Building a 408w
Extended shackles and pull a leaf. Tiny bit of lift and a softer spring rate.
You just need two pieces of plate drilled out for the front. Might need a shackle flip in the rear depending on what you've done.
feellnfroggy
28
Knoxville, TN
A good cocoa butter rubbed in for at least an hour followed by some PB blaster.
throw a ton of dirt in the back and let it sit like that for a while. They'll either soften or break.
