heater, bronco2
extremeema
heater,top pin for redatior, gasfilter (bronco2)
I am having problem where the heater dosent heat up like it should any ideas.plus i dont still have an answer for where the gas filter is and also can u tell me where the cop pins is on the raditor. now can tell me about the cop pins on the raditor be.
Robert_1967
13
White Pine, TN
302/2.9
does your engine get to the right temp??
my heater didn't get warm till I put a t-sat in it.
Robert
Epixstar
3.slow
If your heating up just fine you may just need a flush just look to see how clean the fluid is. The heater core on these is about a 10 min job and 20 buck so a quick change out may be a good idea too.
extremeema
ok thanks on that.
extremeema
copy kat for someone who dont know the jargen can u put it in plain speech.
extremeema
whats the matter b2rich
CopyKat
8
Manitoba, Coldest place in Canada
when your at the drivers door looking at the truck. Get on your knees and look under the truck you will see a body mount and radius arm bracket (attached to the front axle) right under the drivers floor board. On the inside of the frame rail. It's C shaped. You will have to lay on your back to get to this point. There is a round canister. Bigger than a closed fist. This can will be attached to a bracket with a hose clamp. This is your fuel filter.
extremeema
my husband gets what u say but he wont be able to do it on his back he says it is to far up.
BlackBII
Ranger Custom
Truck of Month
982
UT
Hmm..
So the truck is lifted so high that he cannot reach the fuel filter? Short arm syndrome? JK!
Maybe lay on a block of wood or something?
And on the heating issue, are both of your heater hoses getting hott to the touch?
extremeema
but we dont have that and the proerty we live on is sand and dirt
extremeema
Hmm..
that was not nice.
