heat at firewall
slk1
Panama city Florida
I've got a 96 4x4 5.0. does anyone else have a heat problem inside the cab at the firewall?
8,372
Welcome to TRS :)
Can you be more specific as to the location of the heat?
Firewall runs from divers side to passenger side of cab, and from windshield down to the frame.
Engine metal only runs around 200degF, so hot but not all that hot.
Exhaust parts on the other hand run minimum 650degF and closer to 800-900degF
Catalytic converters get hot and get VERY HOT if engine is running Rich
Elutheros
129
Central Texas
Yes, the cab gets hot with nothing but rubber mats on the floor and after cruising 15-20 minutes and no, I don't have a solution. I put that foil covered insulation on the transmission tunnel--it may have helped with noise, but not heat.
8,372
Thinking low profile hood scoop :)
A Working one that channels air to rear of engine, get some air circulation between engine/exhaust and firewall
Maybe a V8 logo on the sides of it, lol.
slk1
Panama city Florida
around the tunnel is where I've got a lot of heat. it's got a rubber floor. ill try anything.
Denisefwd93
74
South East PA
That's why you're feeling heat. Carpet and padding of course also insulate. You could use some sort of foam underneath the rubber.
85_Ranger4x4
17,906
SW Iowa
When I first did mine I left the shifter hole in the carpet open. It was like a steam locomotive going down the highway, it was terrible. Hot air would come in around the shifters and go out the drivers side window, it was a rolling sweat box. :bawling:
I bought a tan $4 rug at kmart that kinda matched the interior and it was like driving any other vehicle going down the road after that.
Denisefwd93
74
South East PA
Pretty common problem on the older Rangers the blend door on the heater is somewhat partially open I don't know if that is one of your problems but I found it on my truck, the blend door cable is behind the glove compartment door on top of the heater.
