- May 26, 2010
- 182
- hell
- Ford
- Engine Size
- 4.0
I know some of you know a lot about computers and what not... here's thesitiation, a friend of mine used to buy electronics at auctions, and sell it for a profit, fixing what is needed to be fixed as required, he fell out of it with a bunch of stuff left over, including this laptop. he no longer has time to sell it all, so he's getting me to do it for him. The laptop in question is an averatec e1200 (i'm sure no one has heard of it) it boots part way, does an averatec logo screen, starts the startup self check, and comes to a doss screen that says:
Intel UNDI, PXE-2.0 (build 082)
Copyright (c) 1997-2000 Intel Corporation
For Realtek RTL8139(x)/8130/810X PCI Fast Ethernet Controller v2.13 (020326)
PXE-E61: Media test failure, check cable
PXE-M0F: Exiting PXE ROM
Reboot and Select proper Boot device
or Insert Boot Media in selected Boot device and press a key_
after opening the computer up, and listening to the hard drive with a screwdriver on the ear, I can hear a few sets of clicks in the drive, as it boots, but no spinning noises. I have pulled the drive out, and tried the old nintendo blow in the connection trick, it didn't work...
I CAN get into the bios while it's booting up, and in the bios in the boot menu, the three boot devices are, in order, [CDROM: SM-Slimtype], [HDDM-IC25N060ATM], [Network: Realtek Bo] with those square brackets around them, and over on the right side, on the "description" section I suppose, it says "A device enclosed in parenthesis has been disabled in the corresponding type menu"
the fact that I can hear clicking in the HDD, but no spinning, and that it has been disabled in the bios, leads me to believe that the hard drive is pooched... right?
next question is what connector/type of drive is this? it says on it "ATA/IDE" but an ide drive has the power connector over on the side, separate from the main harness isn't it? this looks most like a PATA connector, but it doesn't say PATA anywhere on it... I am pretty sure it's not SATA though...
I may just have to throw this laptop out, depending on how much it's going to cost to repair, because now I have to get a set of recovery disks, and possibly a new hard drive...
just curious, i found this file, which looks like what I'll need to re install windows (I don't have the disks, but luckily the sticker on the bottom is still legible) but this says floppy disks, and when cd-rom doesn't work, i should be able to put this onto a cd anyways though, right?
http://www.softpedia.com/get/System/Boot-Manager-Disk/Windows-XP-Pro-Startup-Disk.shtml
