GM Vs Ford Axles
Fabricator
ranger
2.3l
Hey all im wondering what would be the best bang for my buck by getting either a posi gm 12 bolt rear or getting a ford 8.8 or 9.75 and putting a locker in it. what do yall think?
kryptonitecb
19
Fort Worth, TX
8.8 short base, I would only do a gm axle if it was a 14bolt or D60. The rest aren't worth it.
Sent from the road while ignoring traffic
RangerSVT
Oct 09 OTOTM
ASE Certified Tech
53
TRS since 2002 - NW KY
GT-40 5.0L EFI W/AC
Imo, no gm axle is worth getting...
SVT
3.0ranger1227
11
Ford 9.
If you do go with an 8.8 make sure it's 31 spline. A ton more options with the 9 though, except for one certain locker that they don't make for a 9.
17,998
SW Iowa
The Ford 9.75 is a really good axle but you will find options limited for it.
shane96ranger
221
Utah
Ford F150-Stang
4.6 Triton / 5.0
Fabricator
ranger
2.3l
Thank you all for your input I would go with a Ford 9inch but I can't find one anywhere near my price range. I get my axles from the u-pull it yards and I saw a gm 12 bolt with a posi in it with disc brakes for 60 bucks. So far ive only seen one Ford 9inch and it was gutted the next morning I went up to get it. So do yall think I should wait for a Ford 9inch or go with somethin that is on hand now?
snoranger
Professional money waster
ASE Certified Tech
13,729
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
How much power do you plan on making?
What size tire do plan on running?
What are you building?
No one can tell you what axle to use without knowing what you want to do.
shane96ranger
221
Utah
Ford F150-Stang
4.6 Triton / 5.0
The 8.8 is a very capable rear end. It is Fords second most versatile differential IMO. I've owned several over the years, and they are rock solid reliable. You can get one out of a 95-01 Explorer with disc brakes, and they have 31 spline axles. Also, a limited slip is an option - so you may get lucky and locate one. The only drawback is that it will require some fab work.... but from your user name (and considering you had the GM 12 bolt listed as an option) I doubt that is an issue.
Sent from a Commodore 64 using a 300 baud modem
RangerSVT
Oct 09 OTOTM
ASE Certified Tech
53
GT-40 5.0L EFI W/AC
What Shane just said, but another good option would be to use a Dana 60 full float and adapt disc brakes to it. The 8.8 is a good axle, like Shane said, but after I snapped an axle shaft and was dead in my tracks, I highly prefer a full float axle...
SVT
17,998
SW Iowa
SVT
The Sterling 10.5 is a good choice too, I would pick it over a D60 actually.
RangerSVT
Oct 09 OTOTM
ASE Certified Tech
53
GT-40 5.0L EFI W/AC
Yes, the sterling's are another great choice, but traction devices (lockers and spools) are hard to find and are quite pricey. 60's are plentiful and traction devices are abundant and affordable...
SVT
shane96ranger
221
Utah
Ford F150-Stang
4.6 Triton / 5.0
What vehicle used the Sterling?
RangerSVT
Oct 09 OTOTM
ASE Certified Tech
53
GT-40 5.0L EFI W/AC
F250/350 from 86-13. 86-97 was the sterling 10.25, 98-13 used the 10.5. The 10.25 used drum brakes and was 8x6.5, the 10.5 uses disc and is 8x170mm...
SVT
shane96ranger
221
Utah
Ford F150-Stang
4.6 Triton / 5.0
Thanks SVT.
Hey, when you broke an axle, what made you stranded? I thought I read somewhere that the caliper would hold it in there well enough in an occasion like that. Or were you using a drum?
