Gears clash when I try to go into Reverse - manual transmission
Grasshopper
Huntsville, Alabama
2.3L
1997 Ford Ranger
4-cylinder, 2.3L, 5 speed
For a couple weeks now, I've found it difficult to shift gears. The transmission seems very particular about what speed I'm going for it to allow me to shift into gears easily.
Just today, I tried to reverse, and got a sound like I was trying to enter Reverse without pushing the clutch pedal. The gears were grinding against each other. I managed, with a lot of force, to shift into Reverse, and once I shifted it worked fine. A little later, while waiting at a red light, I experimented and again got the gear-grinding sound when attempting to shift into Reverse.
Could I have help identifying the problem and fixing it?
ericbphoto
Overlander in development
16,665
Wellford, SC
3.0L
6"
Almost sounds like the clutch isn't disengaging properly. That's just a guess though.
This message composed solely of recycled electrons. Go green!
planeflyer21
19
Sonoran Desert
That's what mine was doing on my '99 3.0 V6.
The master cylinder was bad. Not a quick fix, as it is buried in the transmission which needs to be pulled, if it is indeed the master cylinder.
Denisefwd93
74
South East PA
You did make sure there is fluid in the transmission right??
Spott
21
SE Idaho
I'm fairly certain you're referring to the slave cylinder.
The master cylinder is mounted on the engine firewall and is connected to the clutch pedal.
It very well could be a faulty slave cylinder, or a faulty master cylinder. Other culprits might be the hydraulic hose, or clutch pedal bracket.
planeflyer21
19
Sonoran Desert
Oops, yes, slave cylinder.
I should know since I've replaced both at one time or another.
rangerenthiusiast
Hudson Valley, NY
If I can offer a bit of advice, don’t drive it that way too long without fixing it. Decades ago, I had a friend who owned an ’85 Golf with a broken shift tube. Rather than pay to have it fixed the cheap @x!#* would just start out in first, wind it out, and manually jam the shifter into third. I ended up inheriting the car (because he owed me money) without realizing what he’d been doing. After dumping a bunch of work into it, I found out that he had blown the synchros out of third gear. I drove it for a while, but the car was never really right.
Grasshopper
Huntsville, Alabama
2.3L
Thanks for all the advice!
My dad says it feels like there is air in the system, but I'm not sure how that could happen since the clutch fluid is full to the brim (and hasn't been low).
I am going to start by bleeding the clutch hydraulic system, and if that doesn't help, I will suspect a bad cylinder or hose.
Does that seem reasonable?
Grasshopper
Huntsville, Alabama
2.3L
Update: We found the problem. It had run low on hydraulic fluid. We bled the clutch and refilled, and now it works fine.
The reason we didn't realize it at first, is a strange one. There's a rubber insert in the fluid reservoir, and apparently somebody had filled that insert, thinking it was the actual reservoir.
I just bought the truck a month ago, as a replacement for Grasshopper, who got fallen on by a tree. :(
This one is called Katydid. :)
Denisefwd93
74
South East PA
