- Mar 9, 2012
- 4
- Ohio
- Ford
- Engine Size
- 3.0
KOEO, (not quite full battery) power to relay (clicks with key cycles, and has hot pins, assume relay works?), power to inertia switch, inertia switch has negligible resistance, power to the pink/black wire at this connection. Likely Friday I will get time to try and chase it further, but as far as I can tell there is no other connection past that besides the one at the fuel pump. Which, as far as I can tell is inaccessible without dropping the tank... any ideas? So far I know I have power that far, and the fuel pump doesn't run. Is there any easy way to jump connections so I can test the fuel pump disregarding any other systems? EDIT: I assume ya'll can figure out that the vicegrips are touching said connection? If you didn't... well now you know.
