Front Axle Swap 88 BII
4.0B2
151
Walls, MS
4.0 v6
sorry i missed that. lol. i tend to not ready everything, my bad...
but yea you got a nice set up. do the rear first in my opinion. that's what i'm doing. its d35.. you could always check out offroadlockers.com they have aussie's for $230 front and $270 rear.. i think that's the prices. something you may want to look into. i'm gonna run the posi in the rear and lock the front first. the posi is nice if you know how to drive it and want great street manners
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
All this is good, but.....couple things need to be cleared up, the ranger 7.5 and 8.8 (28 spline) axles are the same in strength, they use the same axle shafts, the 8.8 just has a bigger carrier/ring gear, even use the same bearings...All explorer axles are 31 spline, and about half are limited slip. From 91-94 exp axles are drum brake axles, 95-2000 are disc brake. All exp axles are sprung under, needing perches relocated to the top of the axle. If you get new perches and keep the original perches in place, they make good jacking pads...What transfercase do you have, is it electric shift, or manual?? If you have an electric shift, I highly advise grabbing the Tcase out of an exp as you can also grab the front driveshaft and then your 35 swap is bolt in. If you have a manual, while 54 manuals exist they are scarce, this would be what you would want, just make sure you get the shift linkage as well. The difference between the 1350 Tcase you have now and the 1354 case the exp's have, is the front output, the 30 is a slip yoke, where the 54 is a flange, similar to your rear driveshaft at the axle. I understand $$$ are probably tight as everyone is on a budget, but some things to keep in mind when gathering parts for your swap...If your D28 is okay right now, my advice would be to start with getting the Tcase and driveshaft and if you have enough, the rear axle. When you get more or if you have enough, the D35 last. I say the 35 last cause there are so many floating around, the rear 8.8's are more in demand than the 35 and would be a little more challenging to find...
SVT
the 8.8 is much stronger then the 7.5. the 7.5/8.8 28 spline shafts and bearings do ok....but the wormy ass 7.5 case and carriers can be exploded with relative ease comparatively.
it seems from the statement theres no benefit of a 28 spline 8.8 over a 7.5.
thats not true...the 8.8 is definatly an upgrade, not as heavy as a sploder unit but better then the 7.5 for sure.
4.0B2
151
Walls, MS
4.0 v6
but... if you're going to the JY to get one, get the 31 spline ex axle and you'll be better off. not like the JY charges more for one than the other.. but the 8.8 of any kind is better than the 7.5 for sure
AllanD
TRS Technical Staff
134
East-Central Pennsylvania
1987... sorta
'93 4.0
the tech library shows it as axle code D2, saw one in our j/y not to long ago. to bad i was broke..
The D2 4.10 axle code applies to the 1995-01 Explorer
Research? there is no FORD reference to those axle ratios being
sold or serviced for US certified vehicles
(there actually is a reference for an export version, but unless you are searching the junkyards of Columbia, Equador or Peru...)
And BTW, who do you think wrote the tech page?
Though I will not accept blame for several of the more annoying errors.
as for the 8.8" axle over the 7.5" the 7.5" is tougher than you'd think...
THE advantage of the Explorer axle is that it has stronger axle shafts, but more
importantly stronger axle tubes.
The disadvantage is the fact that you need to weld spring perches and shock mounts onto it.
Resist the temptation to remove the old spring mounts, buy new they are only ~$25 for a pair.
and the old ones being there act as a guide for installing the new ones.
BTW, I recently saw a Ranger that I thought was kinda slick...
the owner mounted the shocks OUTBOARD of the frame, this let him route is exhause more easily.
The other thing that struck me was that it was a slick way to avoid one of the major interference issues
with installing a Bronco2 tank in the back of a supercab...
AD
AD
4.0B2
151
Walls, MS
4.0 v6
i stand corrected.. maybe the one i saw was put in there aftermarket. idk. regardless, most will go 4.56 (or lower) anyways. i know i will.. as soon as i find my money tree
RangerSVT
Oct 09 OTOTM
ASE Certified Tech
53
TRS since 2002 - NW KY
GT-40 5.0L EFI W/AC
Agreed, the 8.8 is a better choice all the way around. I'm not exactly a fan of the 7.5, but I was just stating the fact that they share axleshafts and bearings:icon_thumby:
SVT
