Ford rims have 15x7x12 stamped on them. What exactly is the 12?
outatime88
37
California
3/4
So I went to the junkyard today and found some of the teardrop ranger/explorer rims and decided to buy five of them even though I wanted to continue using my 14s.
Two of them say F67A 1007-NA and 15x7x12
Three of them say F87A-1007-SA and 15x7x12.0
So what does the 12 in 15x7x12 indicate?
Between these wheels I notice that the structure of the rim is different, the F67A wheels have sort of a step up half way through the rim and the F87A have a tapered style. I need to get a scale but I think I noticed they have a slight difference in weight.
Also what are the chances that these all have the same offset and will they all fit 2wd?
85_Ranger4x4
17,908
SW Iowa
I think rangers always had the same offset.
97RangerXLT
TRS 25th Anniversary
3,964
Fishers, IN
2"
31"
Just a wild guess here... but could the 12 be the maximum diameter of the brake rotor/ drums that the rim will clear?
AJ
pjtoledo
2,979
Toledo Ohio
Fords
3.0 2.3
12 is the offset in millimeters. for reference 12.7 mm = 1/2"
those wheels all have a 1/2" offset.
85_Ranger4x4
17,908
SW Iowa
Rangers also have 1/2" diameter wheel studs.
outatime88
37
California
3/4
But why would Ford use two different dimensional units and not even show a physical representation to know which is IPS and which is metric? Seems like poor engineering practice to me :unsure:
pjtoledo
2,979
Toledo Ohio
Fords
3.0 2.3
don't blame Ford, it's an industry standard (in the U.S.) to define wheel diameter & width in inches, offset in millimeters. backspace is usually inches, bolt circle diameter can be either.
it's one of those "Oh, we thought you knew what we meant" situations
sgtsandman
Aircraft Fuel Tank Diver
U.S. Military - Active
Ham Radio Operator
12,687
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
Yep, that is industry wide. Not just Ford. It can make it confusing when looking to get new or replacement rims. Especially since some rims are listed with offset and others with backspacing.
outatime88
37
California
3/4
Interesting, well I guess its good that I don't have to measure the offset since its already stated.
So here's another question for you guys, as you can see in the photo these two wheels have a different structure, the one on the left has a step and seems to weigh slightly more than the tapered rim on the right. Is there anything wrong with using both rims together?
If the rims do in fact weigh differently (I'm going to get a scale), I should only run the ones that are heavier on the rear(left and right), and the lighter on the front(left and right)? I would think running different weighted rims on one axle would be dangerous.
29679
sgtsandman
Ham Radio Operator
12,687
Aliquippa, PA
Ranger XLT/FX4
Pre-2008 lift/Stock
You’ve gone farther into the rabbit hole than I have. Spare tires on vehicles often have different rims and tires than the rest of the vehicle but are not meant for long term use.
I can’t see where your thinking is faulty. But someone else might be able to give you a more knowledgeable answer.
85_Ranger4x4
17,908
SW Iowa
Running a full-size spare on a steel rim with three alloys I never noticed a difference.
4x4junkie
584
So. Calif (SFV)
Bronco II
2.9L V6
35x12.50R15
I don't think this is something that will matter.
But if you're worried about it, then run two of the same on the front, and the other same two on the rear (which ones go where does not matter, and won't play into a normal 4-tire rotation at all).
FWIW, the unsprung weights on the front axles of these trucks ('83-'97) are already not the same on both sides to begin with (especially on 4WD models) due to the design of the front axle beams.
pjtoledo
2,979
Toledo Ohio
Fords
3.0 2.3
the wheel on the left, stepped one, has clearance for a larger 12" front brake rotor.
the tapered one is for 11.25" front rotors.
since you have a 1997 the rotor upgrade is not do-able, so the wheel differences are a non-issue.
outatime88
37
California
3/4
Ah I see, I had a feeling it had more of a specific reason.
Thank you for the help guys, I'm going to make a trip to another local junkyard and see if I can find any more matching rims and if I can't find anything to satisfy my OCD habit of having everything be the same then I'll just do the two of one type in the front on the other in the back.
