I am not too sure what kind of help you need. To remove the cam cover, you have to remove the throttle body from the upper intake, otherwise there's not enough room to raise the cover to clear the cam supports. Then remove the PCV valve clean air feed.
After that, disconnect the spark plug wires and lay them towards the drivers side.
Then remove the bolts holding the cover in place. Some may have 'extensions' so keep track of them if they do so you can put them back from whence they came.
Remove the cover. It may stick, so be prepared to use a prybar, gently, to break it loose. Clean all old gasket material from the cover and the cylinder head gasket surface.
The rubber gasket will have to bend over the frontmost bearing support. Align the holes with those of the cam cover. You may find the gasket will hold the bolts in place, also keeping the gasket in place. Put the cover onto the head, tighten fasteners, re-connect all you took apart.
tom
