Exit B4 the Rear Tire
RedneckRanger69
Katy, Texas
3.0 L V6
Im thinking about changing up my exhaust system a little bit, I was thinkin about keepin the Flowmaster Original 40 series muffler on but instead of having the pipe come straight out the back, i was thinkin about bending the pipe to where it comes out right before the rear tire. Does anybody notice a difference in sound doing this, also, Do ya'll think a turn-down exhaust tip will make any difference in sound if put on. Im just wondering what wuld sound the best. I want the truck to still have that good deep sounding rumble at idle and sound fairly decent thruout the rpm band. Im pretty sure im gonna get a regular 3 inch diameter clamp on tip, but I was wondering if a turn-down tip of the same diameter wuld sound any different. Let me know wat ya'll think.
BEEFKING69
Blountstown, Fl
FORD
302
yeah ull be able to hear it beter if u exit before the tire and stick with the straight tip cause a tip is a tip no matter how its cut r angled
Mac
183
C. Wisconsin
2000
199
My feeling is just that, a 3" tip is going to make it look like a ricer!
Dave
Hahnsb2
36
Battle Ground WA
Ford-Dodge
4.0-5.2 Turbo
IMHO 3" tip looks fine on a ranger. I just built a before tire exit exhaust that goes over the frame on my buddy's ranger (forum member Grunizzle), I'll try and get pics up soon.
Heres the pics.
Sasquatch_Ryda
Forum Staff - Retired
108
Terrace, BC, Canada
Solid Axle Swap 4x4
40s
I really try and discourage people from doing a side exit in front of the rear tire.
You should see what it does to your brakes and wheel on that side of the truck. Major corrosion problems and it will cause yellowing of your rim if it is aluminum.
Ford tried that style of exhaust on the 97/98 f150's and recalled them afterward and put a full length tail pipe on them behind the rear tire and replaced the ruined wheels as well.
Hahnsb2
36
Battle Ground WA
Ford-Dodge
4.0-5.2 Turbo
Ford still did it on the lightnings :dunno: I've never had any problems with the brakes, yeah my wheel got a little discolored but they were crap anyways and they cleaned up, I've run the before tire setup for 2 years.. I think it's an effective way to get the exhaust out from under the truck and when run over the frame it's very protected, much more so than a tail pipe and they sound better.
RedneckRanger69
Katy, Texas
3.0 L V6
Does the exit before rear tire system still produce that resonating sound, cause thats the key im lookin for! I want the truck to rumble at idle. and sound fairly good thruout the rpm band, even though the 3.0L is a revver.
simonsays
October 2010 OTOTM Winner
9
Carpinteria
here is a pic of my exhaust on my truck.. i havn't had any issues with it and i love the way it sounds. i didn't use a 3in tip i used a 2.5in tip.
Ranger97XL
I think it sounds good, i dont know if a turn down will matter if its not under the vehicle, my mustang had a turn down under it and it definitely made it louder. I live in chicago so 90% of the bridges are metal grates and whenever I drove over one it sounded like the car shut off it would get so quite
I only used a 2" tip
RangerSVT
Oct 09 OTOTM
ASE Certified Tech
53
TRS since 2002 - NW KY
GT-40 5.0L EFI W/AC
I love mine, some people have asked me if I have a V8 in there, no issues with brakes, discolored rims or tires, very deep rumble, of course the 6" diesel tip helps
SVT
RedneckRanger69
Katy, Texas
3.0 L V6
Holy Shit! A 6 inch Diesel Tip on a Ranger, Lol, thats crazy, aite well I think im just gonna build my own side exit exhaust system. Im gonna use 2.5 inch diameter pipe behind the the last catalytic converter, running into a Flowmaster Original 40 series American Thunder muffler, with 2.5 inch diameter pipe running out of the muffler turning 90 degrees to the right and to finish it off, Im gonna go with one of those 3 inch Single Inlet/Double Outlet tip. Im pretty sure it'll sound good, Im gonna have to move the muffler up closer to the catalytic converter to have enough room to make the pipe do a 90 degree turn to the right. Does anybody know if moving the muffler a little bit towards the catalytic converter will affect the overall sound output, Im pretty sure it ain't gonna change, but I can never be to sure, Does anybody have any saying on that?
Z3CHYD
17
Lancaster, PA
3 front 5 rear
225/60R15
^ well i kno if you move the muffler closer to underneath the cab, it might get a lil "drony" in the cab, but other than that it should sound sweet, lets see some pics when ur done :)
paxlineman
Paxton, Ma
heres a pic of my side exit before the rear tire
Z3CHYD
17
Lancaster, PA
3 front 5 rear
225/60R15
Here's my exhaust setup on my 86 2.9l, I never had any issues with rust or discoloration and it sounded decent too
