EDIT: FORSCAN IS WORKING New Key for my '03 Mazda B3000, ForScan no longer accessible? Is a bypass an option?
bhgl
200
Northern Ontario, Canada
Mazda B3000
Howdy folks,
I'm looking to get an extra key made for my 03 B3000 since when I bought it it only came with one.
I can find suitable keys, and a place to cut them no problem. The trouble is getting the transponder programmed.
The local Ford Dealership is quoting 300$ just to program a new key, no cutting included. Whack. So I found out that many folks were able to program their own keys for a decent amount less using this guide in the tech library. Trouble is it appears that most of those links are dead, and any links to ForScan I've been able to find on google aren't much help either.
I obviously don't want to order the related scan tool and key until I know I can do it for sure, anyone have some experience with this? I'm open to bypassing the anti-theft altogether if it isn't too much trouble, since I'll be installing a hidden kill switch regardless.
Any help is appreciated, thanks!
superj
2,659
corpus christi, texas
ranger edge
none
none
235s
drives a stick shift ranger
forscan should still be available. my son has the full version and i have to lite version on my phone. google forscan isntead of hitting the links and it should be easy to find a working download
fastpakr
2,841
Roanoke, VA
Honestly the hardest part may be finding a locksmith that will cut your key for you without requiring that you buy the key from them and have it programmed on site.
I'll try to find current forscan links and suggest an OBD2 port adapter. Didn't realize until your post that all those links were dead.
Edit - has anyone reading this thread used the Forscan website recently? Not sure if it's just down at the moment or if it's no longer in action. I haven't needed to do anything with Forscan in a few years.
superj
2,659
ranger edge
none
none
235s
bhgl
200
Mazda B3000
Much appreciated! For reference I am in Canada, and would prefer not to get nailed for shipping/import duties when ordering a obd2 port adapter.
It seems I may be the first to remark that ForScan is dead? At least on this forum. Your help is much appreciated!
fastpakr
2,841
Roanoke, VA
Honestly the question doesn't seem to come up that often. And I was wrong about the website not working, looks like it's just blocked from work. I can get to it on my phone. Sounds like superj can point you in the right direction for an adapter. Can you order from Amazon without dealing with import issues?
fastpakr
2,841
Roanoke, VA
Other than the Amazon page for the adapter, what dead links did you run into?
bhgl
200
Mazda B3000
It appears there are scanners available on amazon that I can look into.
As for the site being down, gosh this is kinda embarrassing, I'm currently posting from a workplace networked computer, I just tried accessing it from my phone off network and sure enough. It worked!
fastpakr
2,841
Roanoke, VA
No worries - I ran into the same thing at first. Since it just timed out rather than throwing the typical site blocked error I didn't realize what had happened.
Good luck and let us know how it goes!
ekrampitzjr
1,079
Virginia
Am I the only one who thinks "ForScan" is a very unfortunate name? What genius at Ford thought of using a name that sounds a lot like "foreskin"? :LOL:
bhgl
200
Mazda B3000
Man I've been giggling about it to myself all day.
fastpakr
2,841
Roanoke, VA
It's not an official product, so my guess was always that it was an intentional joke.
8,372
Any locksmith can Clone your current key so no programming required
PATS uses an RFID Tag embedded in the handle of the key, no batteries required
RFID Tags can be made with a number encoded on to them when they are made or left blank with no number
They look like this: https://tritonstore.com.au/wp-content/uploads/components-of-an-rfid-tag.jpg
But way smaller, lol
PATS has a powered antenna ring around the key slot(transceiver)
With key on that antenna sends out an RF burst
RFID tag's antenna uses that burst as power, and sends out its unique number in reply
PATS antenna sends that to the PATS module/software
The number is compared to pre-programmed numbers and if a Match is found then THEFT light goes off and you can start engine
If no match then THEFT light starts to flash rapidly and no start
A Clone key with the same, already programmed, number is the SAME KEY as far as PATS is concerned
Its not a copy so in some way "diminished", it's the same process that an RFID tag goes thru at the factory or in a locksmith's shop
Locksmith uses an RFID tag reader, like PATS does, but gets the number from the working key to hold in memory, like PATS does during Programming mode
Locksmith then Writes that number to a Blank RFID tag in a new key, the same as was done at the RFID tag factory
Locksmith then Cuts the new key to match the old key for the Lock part
Locksmith will have Blank PATS keys, call around, see who has the best deal for Clones
Literally takes less time to Clone the key than to cut the key
JoshT
1,798
Macon/Fort Valley, GA
Definitely not dead. Just downloaded latest version from the website last night.
It does look like they might have updated the site a little though, that would be the first time in a while. I don't recall the like for the subscription (enhanced version) working the list time I was there. IIRC everyone was using the free trials repeatedly and there was a donation link. Could be wrong about that though, until now I never had much interest in, or need for, the paid version.
FWIW I have and use the recommended OBDLink EX.
I don't know about that. I think the joke is purely English language, but I suspect the program may have originated in Russia. That is my best guess as to why that simple of a page has an option to switch language to Russian.
I think it was a simply a catchy combination of Ford and Scan, but the immature part of our minds make the association.
True, but having the second key as a cloned key looses certain capabilities that are available to the owner without special tooling. Namely the ability to program another extra key without paying a locksmith to do it.
If I only had one key, I'd much rather the locksmith program me a new key (vs a clone) so I can program a third myself. Can't do that if you only have clones.
No members online now.
