kimcrwbr1
- Dec 6, 2009
- 46
- maplevalley WA
- ford
- Engine Size
- 2.8l
it`s fine to hook the advance to manofold vacuum if your carb is not ported and if your running the square stock coil that comes with the truck you don`t need a resistor they ard made to run battery or charging voltage. but if your running now and get good spark the way it is go with it. there is a resistor for the blower motor just trace the wire from the blower its either switch wires or resistor block there is a 8 wire connector by the coil the red and whit wire goes to the temp sensor on the thermostat housing and there is a yellow white wire for the fuel guage. If the temp sensor was not changed with the motor you will need to get one for your year ford to run the guage it might be for an idiot light just take and ground the wire for either the fuel or temp and see if the guage registers with the key on they should be getting a lower pulsing voltage from 0 to 8.6 max on mine I didnot trace the fuel level wire not sure if it goes through the firewall with the temp or just up in the cab somewhere but the oil pressure wire goes through the same plug as the water temp then into the big loop maybe they got cut in the frenzy of removing the emissions wire harness I carefully took it apart and only cut three wires to remove it so basically you turn the ignition either on or on accy and test for the wires that give a pulsing voltage ground that wire and see what guage it goes to and when you plug it in it will either work or you need a new sensor
