Dual Fuels
willfixx2
I just bought a 1994 Chevy 1 ton Step Van. It has two tanks. One for propane and one for gasoline. There is a high pressure gauge under the hood that is reading zero lbs. The gas gauge was reading more than 3/4 tank full. For my 98 mile trip home the gas gauge did not move so I stopped and got 10 gallons. My question is, will this truck run off propane and gasoline? I did not see any controls in the cab to switch from either. I don't know which fuel I was using. Though the pressure gauge was reading zero perhaps I was still burning propane because the truck would stumble and slow to about 45 mph. It would pick up after a while to 65 mph. If any one knows about this type of setup, please respond. Thanks.
D.J.
Extreme Southeastern Illinois
V-6
Somewhere in the truck either underhood or behind seat their should be a switch setup to change between fuels. it will be a switch that should be labeled gasoline and lp gas. Before switching between gasoline and lp gas have some lp fuel installed in the propane tank and check for leaks. I would recomend putting in a FEW gallons of propane and not to fill this tank untill you make sure it has no leaks! The person that puts lp fuel should help you determine if it leaks or not! Also they could probally help you determine where the switch, I mentioned earlier, is. I hope this makes sense to you!:D
willfixx2
Thanks for the info. This is just another project truck that I thought was a good deal to buy. This truck actually uses compressed natural gas. (CNG) I found the switch but it is not labeled, maybe it wore off. I have heard of trucks using butane, propane, etc. but I need specific information on my setup. I'll keep searching and perhaps talking to others until I get the info needed.
Frank The Tank
43
South
I'd have been scared to drive it without researching it.........
was it factory? I've never heard of that (other than in the 60's..... with propane) if so I'd be looking for an owners manual.
If a reputable company did it aftermarket I'd contact them, and if a guy did it in his garage I'd still contact him......... before somebody lights a cigarette beside your rig at the gas station and has a really bad day. (I like the check for leaks idea and change/test gauges idea)
Frank
