Dual front swaybars!
kwtorbe
After spending months searching the salvage yards for a 1-1/8" 98+ 4wd front sway bar to upgrade my '03 2wd Ranger with no luck, I had an idea....DUAL FRONT SWAY BARS! :icon_idea: This Saturday afternoon I picked up a second 98+ 2wd sway bar ($17) and endlinks, some 1/4" plate steel (freebie), 2 x 12" 3/8" all thread, 2 x 3/8" nylon lock nuts, 4 x 100mm frame bolts, and a bag of 25 3/8" washer ($11).
I then cut out plates and drilled holes in the 1/4" plate to match the frame brackets. Next I bolted the frame mount bracket with the 1/4" plate on top and welded them together. I bolted them together to keep it all squared up while welding. After it cooled I painted them and then bolted it all up. To make the endlinks work I sectioned ~1" of material from the factory sleeve and pieced it all together combining the 2 sets of endlinks I had.
The result: I notice much more control on the highway, and I notice no change in ride quality when going straight. Corners are fun and I love it.:yahoo: I am now looking for 2 x 98+ 4wd 1-1/8" sway bars for even more control :headbang:. My brother is going to install 3 x 1" sway bars on his E250 :icon_welder:.
By the way, I also have Mustang rear disk brakes, a 1" rear Bronco II sway bar, and Explorer OHC - I'm running out of things to do! Next project will be 17" Bullit wheels to get rid of all that tire roll. Anybody know anything about stiffening up a 2wd frame?
norcals91
Nice alternative to going with a more expensive aftermarket unit. Looks pretty clean. You can stiffen up a 2wd frame by boxing it in and/or caging it into the frame. To be honest, my experience is with 97 and earlier, but I assume that current rangers use c channel frames...never looked on the newer ones.
ForOffRoadDriving
18
HIGHLAND, MICHIGAN
FORD
3.0L
when i first read this i was thinking FAIL, but after looking at the pic i think it turned out great, especially if youre experiencing less body roll.
BONES
4
Canada Eh!!
gt40 5L
X2 ^^^^^ :icon_thumby:
