du hell is wrong with my truck?!?
Ak907Girl
16
Anchorage, Alaska
4.2L/ 11,370Miles
battery is fine, oil is fine, belts are fine, I don't know too much about where everything is in my engine. So far since I've owned the truck I changed out the alternator, new spark plugs, new timing belt, new serp belt, new blower motor, new spark plug lines, and new battery. Not a single bit of carrosion on the battery, I keep it nice and clean. I put fuel injector cleaner in once a month like its a religion. My previous vehicle had a plugged up CAT, which is what it seems to be acting like, but I'm not sure, I'd check but it's current like -2 degrees outside and I don't have a garage, nor a jack. lol
LIMA BEAN
140
ALASKA
vacumm leak maybe? the vac line to my brake booster came off and it sputtered and whatnot. but hell I don't know much about diagnosing engine problems haha
If it was a vacume leak it most likely would be constant and this problem seems to be intermittent.:dunno:
Rose2300
7
ID
Toyota
3.4
LIMA BEAN
140
ALASKA
I have a manual for it if you need to borrow it. Im midtown on C street.
Mark_88
240
Ontario, Canada
Dordge
3.3 Fuel Injected
Love Thy Neighbor
-2 isn't too bad...oh, you mean US dollars...that's different...
There's not much to these engines...but troubleshooting can be a bit daunting at first...seems like you know about maintenance though...I'd check the fuel pressure if you can get it running...or have someone check the codes...if no codes then it can be a bit costly swapping in parts...
Codes can...sometimes...
Ak907Girl
16
Anchorage, Alaska
4.2L/ 11,370Miles
I've got a manual for it, I'm just still learning how to work on it. I'm over off Northwood and 88th.
LIMA BEAN
140
ALASKA
PM sent, check your inbox.
Ak907Girl
16
Anchorage, Alaska
4.2L/ 11,370Miles
I'm gonna cut out the CAT and see if that fixes it. It'll run just fine till the CAT gets hot then it'll idle rough, but still kind of run. Now the question is to Straight pipe or spend $300+ on a new CAT.
Mark_88
240
Ontario, Canada
Dordge
3.3 Fuel Injected
Love Thy Neighbor
Well, if you cut out the cat and it runs better, a new cat would be in order...the old one might help offset the cost...scrap yards pay cash for them due to the platinuim...depends on the year though...might be worth checking out...
triumphrider-1
14
Port Huron, MI
Ford F150
3.7L
If the catalytic converter were plugged, partially or wholly, the problem should be constant. I'm wondering if its the O2 sensor, but I don't know of a way to test them.
88SXT
9
Beaufort SC
2.9
sorry, i missed if you had checked the fuel pressure. i would check that since a fuel pump/filter is cheaper than a new cat
RatDog8o8
140
Des Moines
2.9
The deciding factor in the new cat vs straight pipe issue would be if local and/or state regs require one for emissions compliance. I don't have one on my '92, but there's no state inspection here.
kimcrwbr1
46
maplevalley WA
2.8l
That is a good start check all the vacuum lines for cracks or loose fitting ends. Pull the PCV valve and shake it if it dont rattle replace it. +1 on the visual inspection look for any cracked loose wires maybe a intermittent short somewhere or a bad ground. GL
flyinryne
Afghanistan
2.3L Turbo
When i worked for ford used to see this sorta thing happen all the time on the 2300's, Expecially when it started getting cold...usually Idle air control valve is sticking, EGR sticking,or throttle position sensor taking a dump. Idle air is cheap just buy another one anyways if you havent done it in a long time, you can usually check the TPS with a multimeter pretty eacy, and egr just buy some carb and choke cleaner and a wire brush and have at it.
Ak907Girl
16
Anchorage, Alaska
4.2L/ 11,370Miles
Ak doesnt require ims anymore, and its starting to be more consistan it the more i drive it around. It starts dieing when its warm.
