- Apr 13, 2009
- 5,107
- Calgary, Canada
- '91, '80, '06
- Ford, GMC,Dodge
- Engine Size
- 4.0,4.0,5.7
- 2WD / 4WD
- 4WD
I've been broke my whole life. That's not going to change anytime soon. So....
I wouldn't weld the rear diff, you will burn thru tires and have much more strain on the drivetrain. I would try a simple cheap trick to make a limited slip with your stock rear; add an extra side gear shim or as many as you can fit. It wears out fairly quick but I doubt you will get many miles on your truck before something breaks anyway. I personally done this on a 9" and a d28 front pumpkin. It works. I've never done this on a 7.5" or 8.8", but I don't see why it wouldn't work. Costs are the fluid, gasket, and shims.
