Doing a "weekend" project
SPSully
New Hampshire
Today's project is figuring this part out.. I'll probably go look at the exploder to see where they originally bolted to.
1996xlt
23
NC
Interested with what you come up with, I'm about to do the same swap. ^^^
SPSully
New Hampshire
Darker one is from my 99... won't fit on the 97 bracket, but the 97 won't work with my seat belts.
Going to cut this tab off to make that part work... But I'm still working on the rail the seatbelt slides on as you move the seat
Sent from my SM-N900R4 using Tapatalk
SPSully
New Hampshire
This is the rail system the explorer seatbelt moves on. The hole with blue lock-tite is where the belt bolts in.
This how the factory ranger bolts in. Note the hole for that tab I want to grind off.
SPSully
New Hampshire
Bent the bracket about 20-30 degrees, put a 2 1/2" bolt through with washers as a spacer. This is a life saving mount, so use the right strength bolt.
Eventually I may make a better spacer, but for now the washers worked like a champ.
SPSully
New Hampshire
Do not do that washer idea... pull the sliders off the seat and do this
The tabs previously mentioned still need to be cut off, and the driver's side and passengers side need to flip. Your seat belt warning won't work like this, but I already had mine disabled.
SPSully
New Hampshire
Everything is done... too dark for pictures though.
SPSully
New Hampshire
Sorry about taking so long, but I've been swamped with work stuff today.
Here is a quick shot of everything put back together
SPSully
New Hampshire
This is harder to take pictures of than I thought...
uploadfromtaptalk1443287553336.jpguploadfromtaptalk1443287563402.jpguploadfromtaptalk1443287575580.jpg
SPSully
New Hampshire
The pictures make the seats filthy still..... what the hell. They look much better in person. Maybe its back to olive oil treatments on tuesday.
XLTsplash
160
CA
2.3L
ts_ranger_st
What year Explorer seats are those? Any mounting issues? Thanks.
ATX
11/2014 MTOTM Winner
MTOTM Winner
Austin tx
Built not bought
They look like my 96 expo eb's just not eddies I think
I just wanna go fast [emoji48]
ts_ranger_st
Do you know what kind of mods need done to fit a 1999 Ranger extended cab?
