There are no hubs to engage or disengage like your old Ranger. The front driveline is always turning when the vehicle is in motion. Engaging 4x4 is simply connecting the front driveline to the rear through the transfer case.
The newer Rangers (2002-up) don't have hubs at all. The front axle shafts and front driveshaft are always spinning, even when it's in 2wd. So no, you don't have to back it up, because there is nothing to disengage.
I didn't know that!
Wouldn't that mean more wear and tear, more rotating mass, more drag, less gas mileage, etc? Or am I being paranoid? does it matter that much?
Are the "pulse-vacuum hubs" what I have on my 1987 Bronco II 4x4 with the electric 2-to-4WD shift button? If so, how do they work? (Or not work . . . ) Thanks.
No PVH hubs didn't come around until the late nineties (1998 IIRC) you just have good old auto hubs. Sorry I can't telly you how they work never looked into it.
The older locking hubs 1997 and prior locked mechanically by turning the driveshaft. When you shift into 4x4 at road speeds there is a clutch in the t-case that spins the front driveshaft up to speed before it locks into 4WD. This all happens within a second or two. When it spins the front driveshaft innitally it locks the hubs.
When you engage it from a stop, as soon as you start to roll they lock in.
You can try this out by reaching under the truck and turning the front driveshaft with your hand. It should turn about 1/4 to 1/2 a turn and then you will hear a click as the hubs lock and the driveshaft will no longer turn.
For
a small yearly donation, you can support this forum and receive a 'Supporting
Member' banner, or become a 'Supporting Vendor' and promote your products here.
Click the banner to find out how.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
