dangerranger1983 build
dangerranger83
5.0 HO under the hood!!!
54
Lafayette, IN
5.0 HO carbed with an np435 and np208
The d30 stays, only a matter of time before the crappy cv joint was going to fail.
Rowdy Fitzgerald
Hog hunter
Firefighter
EMT / Paramedic
372
Nevada
5.0,4.0
Solid Axle Swap 4x4
6”
Lol that thing will quit you when you need it the most every time!
Just swap to 1/2 tons and you won't have another problem.
Me on the other hand I've been breaking U-joints. Next is shafts lol
dangerranger83
54
Lafayette, IN
I'm not even hard on mine. Didn't help that the boots ripped years ago either.
17,979
SW Iowa
My D28 still has the original u joints in it... Just sayin'... :icon_twisted:
dangerranger83
54
Lafayette, IN
I wasn't intending on going through a rock and bolder filled creek bed that day either. I was fine till what I think I kicked it out of 4wd to late when I was turning and on pavement going to the offroad park parking lot. That's when the noise started. I have yet to even try 4lo, the granny low first gear worked great all day but I want to take the pressure off it.
Rowdy Fitzgerald
Hog hunter
Firefighter
EMT / Paramedic
372
Nevada
5.0,4.0
Solid Axle Swap 4x4
6”
And that's why I went with the D44. I wasn't expecting to get crazy with my tuck but I get carried away. Now I'm gathering the essentials for 1 tons. Thinking about building a rear 609 for her...
escort_gts
02/2012 04/2013 04/2014 OTOTM Winner
16
Fort Wayne, IN
4.0, 5.0
The 44 and 30 use the same u joints and pinion size. There really isn't that much strength difference between the two. The 44 does have stronger inner c's and thicker axle tubes. But reinforce those weak points on the 30 and all is good. I've wheeled my 30 for 5 years and only replaced on u joint. Just saying.
Sent from my SM-N920T using Tapatalk
17,979
SW Iowa
Yeah, the 30 and 44 (and even 35TTB for that matter) are pretty close strengthwise.
dangerranger83
54
Lafayette, IN
Going d44 would also make me have to get different rims and other things I can't afford.
Rowdy Fitzgerald
Hog hunter
Firefighter
EMT / Paramedic
372
Nevada
5.0,4.0
Solid Axle Swap 4x4
6”
I knew the 35ttb was close in strength but I didn't know the 30 was that close.
dangerranger83
54
Lafayette, IN
The d30 has better aftermarket and fewer moving parts.
Rowdy Fitzgerald
Hog hunter
Firefighter
EMT / Paramedic
372
Nevada
5.0,4.0
Solid Axle Swap 4x4
6”
Than the 35? Definitely fewer moving parts. I would have thought the 30 would be considerably weaker than a 44 though.
17,979
SW Iowa
Close enough that if the 30 won't do it you might as well skip to the 60.
I think the 35 is somewhere between the 30 and 44 but I don't know that the difference is huge.
dangerranger83
54
Lafayette, IN
It's between with the ring and pinion gear being slightly stronger.
dangerranger83
54
Lafayette, IN
Just learned this. A 95 crown vic calipers and pads are bigger and will bolt to an explorer 8.8 rear end that already has disk brakes ofc. The pad part number from autozone is DG674A. You gotta watch which calipers you have. The pistons are steel and some are "phenolic "plastic... The hole on the middle of the piston is smaller on the plastic then the steel or larger clips. That part number is for the little hole and plastic calipers.
