dangerranger1983 build
dangerranger83
5.0 HO under the hood!!!
54
Lafayette, IN
Well planning out how to reinforce the tracbar mount and this is how I plan to attached it to the engine xmember along with where I'm going to mount the cb radio which I need to get a mount for.
Sent from my SPH-L710 using Tapatalk
escort_gts
02/2012 04/2013 04/2014 OTOTM Winner
16
Fort Wayne, IN
4.0, 5.0
Same place I mounted my brace....hmm....you copying me again? Lol
How about mount the CB on the ceiling?
Sent from my Rooted SM-N900T
dangerranger83
54
Lafayette, IN
No space on the roof, I have a map light/clock HOC.
Add soon add I get my dad's vise I can get the brace made, had to be bent a bit too fit right.
Rowdy Fitzgerald
Hog hunter
Firefighter
EMT / Paramedic
372
Nevada
5.0,4.0
Solid Axle Swap 4x4
6”
How's the progress?
dangerranger83
54
Lafayette, IN
Well, got my tbird "fixed", hesitates when taking off from a stop and at speed dive I dud the intake change on it, so I need to get it hooked to a scanner and go from there, but I'm hopefully going to be starting on the trackbar reinforcement soon, have everything to do it except time and since the car isn't 100%, I don't want to start on something like that and then it have an issue and I'm SOL on a vehicle.
Rowdy Fitzgerald
Hog hunter
Firefighter
EMT / Paramedic
372
Nevada
5.0,4.0
Solid Axle Swap 4x4
6”
Have you checked the fuel pressure? Or do you think there's a vaccume leak?
dangerranger83
54
Lafayette, IN
According to codes pulled, it's a miss on bank 1 so I'm figuring out what bank one is on it.
Robert_1967
13
White Pine, TN
302/2.9
you might also want to pull the mass flow thing, and clean it, I know it helped a lot on my Father-in-Laws Explorer when I cleaned it, it had a miss, and hesitated on pulling out from a dead stop.
also helped the fuel mileage too.
Robert
posted using a broken computer running dos 1.1.
dangerranger83
54
Lafayette, IN
dangerranger83
54
Lafayette, IN
Been awhile but anyways got this tach for free, but trying to find out what brand it is. The small tach is gone now and the new one is hooked up but the truck won't start and my volt meter is gone so I will have to go to HF tomorrow to get one and see if I'm getting voltage to the coil. Nothing changed while wiring this tach in, same wire locations as the old one, which I found out its ground wasn't hooked up causing it not to work on the small one.
Maybe next will be getting my temp gauge in after I figure why she's not starting.
Rowdy Fitzgerald
Hog hunter
Firefighter
EMT / Paramedic
372
Nevada
5.0,4.0
Solid Axle Swap 4x4
6”
Start with the basics: air, fuel & spark.
dangerranger83
54
Lafayette, IN
Its getting air and fuel. So.tomorrow going to harbor freight to get a volt meter and go from there. Right now the truck battery is charging and it has auto shut off.
Rowdy Fitzgerald
Hog hunter
Firefighter
EMT / Paramedic
372
Nevada
5.0,4.0
Solid Axle Swap 4x4
6”
Good deal!
dangerranger83
54
Lafayette, IN
Engine started up, guess I flooded it earlier today l. Here's a picture of the tach working. The back light on it changes to a warmer color as I come closer to my set rpm to where it tells me to shift, 3000 rpm, which is what I have it set at. I'm idling at 1000 rpm so I need to turn that down a bit. Not bad for what I'm told is a Chinese brand and for free. Going to get the wired into a harness tomorrow and singe huge house clamps to hold it onto the steering column better.
Rowdy Fitzgerald
Hog hunter
Firefighter
EMT / Paramedic
372
Nevada
5.0,4.0
Solid Axle Swap 4x4
6”
Sweet! Now you'll be able to watch your RPMs for better MPG's.
I'd like to install on in my rig too.
