Dana 28
Littleblue86
I have the Dana 28 in my 86 bronco 2. It has a carrier break and I need to find a new carrier to upgrade into so I can upgrade to 4.10. I have a Ford 9 inch rear I plan on picking up at has 4.11 in it. I have searched the web and can not find a carrier that would allow over a 3.45 gear ration in the Dana 28.
bf750
12
Ky
2. Crap
It is what it is
get a dana 35
BlackBII
Ranger Custom
Truck of Month
983
UT
A Dana 35 is a nice upgrade, and easy to do. But if you want to stick with the 28, look for a 2.3 4x4 Ranger in a junkyard and pull the diff. They usually have 4.10's. A couple years ago I scrapped the Dana 28 that came with 4.10 in my Ranger from the factory because I figured no one would want it.
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
carefully remove it. clean it up.
then....
gently
very gently.....
set it down into
a properly prepared...
dumpster.
Captain Ledd
39
Michigan
302, 2.3
If you're not making mistakes, you're not learning.
BobbyWalter is absolutely right.
The D35 is better in every way except ground clearance, and even then not a whole lot. 1995-1997 Rangers will have better brakes. Radius arms will swap, it's a bolt-in affair. And 4.10's are easy to find for them, maybe not quite as much from the factory though. All TTB D35's use the 3.55+ carrier, no breaks.
Littleblue86
The biggest reason I am not looking for a Dana 35 or something else is because I just put new axle shafts in and new ujoints in the Dana 28. I’m now invested into the axle and don’t want to waist that money. Otherwise I would.
Spott
21
SE Idaho
If you want, I've got a complete Dana 28 center assembly with 4.10 gears. Gear teeth are lightly-moderately worn. It needs a complete master rebuild kit, as the old bearings and seals were destroyed when I got it. I disassembled it, removed the bad bearings and seals, and cleaned it completely, so it's ready for rebuild.
I was going to install it in my '88, but then that truck got squashed in an accident, and I don't need it for the '97 I got as a replacement.
I'm thinking maybe $50 + shipping from 83274. PM me if interested.
turbo91xlt
63
Goshen, NY
1992
Many automatic transmission equipped B2s & 2.9 rangers had 4.10 D28s axles. Only the '89 2.3 4x4 is guaranty to have a 4.10 D28. With the 1st gen ('83-'88) 2.3 4x4s its a crapshoot as to what gears they had in them. I've seen then with 3.45s, 3.73s & 4.10s factory haha.
