Cracked manifold, worth fixing?
arrabil
Lexington, KY
I bought an exhaust manifold for my neighbor to replace the one his kid cracked, then his kid proceeded to crack that one. I don't remember having this much trouble with curbs at high speed when I was learning to drive... but anyway... this crack is pretty small as opposed to a complete shear like the first time.
Can the crack be filled/repaired?
Or should I just have them find another junkyard manifold?
My neighbor has every conceivable metal working tool in his shop if that somehow helps.
Thanks!
Capt Jay
25
Minnesota
'93 body.
Ford(ish)
302
Get different ones. You can't weld pot metal.
gw33gp
538
Costa Mesa, CA
4.0 SOHC
33"
I am very sure the exhaust manifolds are not pot metal. Typically they are cast iron. I have seen brazed cast iron manifolds hold up on farm equipment but I don't know if it would work on a Ranger.
Brazing would most likely cause distortion and that would require machining the sealing surface flat to keep the exhaust from leaking. Probably better to get another one.
baddis
6
Avon,il
2014
4.0 Sohc 1.5 ecoboost
if you bolt the mounting flange down you can arc weld cast .bolt it flat so the mountig flange doesn't warp. welding cast takes alot of heat . so it might be more cost effective to just replace the manifold
arrabil
Lexington, KY
What about some kind of exhaust filler material I've seen at the auto parts store? I used some in another vehicle but it wasn't to fill a manifold crack.
What the hell is pot metal?
Explorin94
Law Enforcement
Firefighter
EMT / Paramedic
19
Farmington Il.
You can actually weld that manifold like Baddis and GW33GP said but you have to get the metal to where it is almost flowing before you can strike and arc. I have done it but have used and old cracked head because of the heat involved. Once it was welded I left the manifold bolted to the head until it cooled down. May be worth just finding another one and have the kid put it on and see if he thinks it is easy for you to keep doing it.
arrabil
Lexington, KY
Well, that I'll give the kid. I made him do all the work while I stood there drinking Natty Light. He got the rivets off to remove the coil bucket on both sides (first time both manifolds were SHEARED). He snapped all the manifold bolts himself. His dad made him watch while he drilled out the heads. I made him reassemble everything and sent him to the store for all the parts. That was after we already had the axle out to replace the radius arm bracket he bent.
Then he Britney Spearsed it... ooops I did it again.
17,884
SW Iowa
v-8power
31
Huntington, In.
It can be welded but it will require a lot of prep.
First you need to drill a SMALL hole at each end of the crack. Then heat the manifold up
and peen the crack. Then wire brush the area to be welded. Take your electrodes for welding cast and do it up. If you do it right it will not fail. Good Luck
17,884
SW Iowa
You can weld cast but if the kid keeps hitting curbs it may make the area weaker to be broken again.
MAKG
19
California central coast
If this is an older vehicle, get a good manifold from the junkyard. It's not very expensive and a dang sight less work.
arrabil
Lexington, KY
We have the two most brilliant junkyards near us [same owner]...
-How much for this taillight?
-Seventy-five bucks.
-How much for this bumper piece?
-How much for the seats?
-How much for the exhaust manifolds?
-What doesn't cost seventy-five buck?
-The engine and transmission.
-Half these things cost less than $50 new.
-Then what are you doing here?
So I'd have to mail-order a manifold from someone or car-part.com.
What about this stuff:
Exhaust manifold repair kit
Says its good to 2000 degrees.
MAKG
19
It's a steel-impregnated epoxy, right?
I'd be quite concerned about thermal expansion. Exhaust manifolds expand substantially between cold and highway-speed. At a minimum, you'll need to "stop" cracks like you do on windshields (drill a small hole at both ends), and clean the surfaces carefully. And I think it will still re-crack.
Isn't there a less problematic junkyard around? That really is the best solution....
arrabil
Lexington, KY
I don't know about the steel impregnation and I don't know of any other junkyards near me. I could find the Maryland Yellow Pages I guess. I wish one of those places by Allan would open up here!
I will print out this thread and my neighbor can decide for himself. Thats the best course of action.
Thanks again.
