corerftech
- Apr 22, 2021
- 84
- Memphis, TN
- Ford Ranger
I decided on one of the two V8 swaps I am in the process of:
To stick with a manual trans.
I procured and M5R2 for a stock Explorer engine yesterday here in TN, 90k miles, its like new!
Still need a slip yoke!! thats a request if someoen has one.
Nonetheless:
As I have concluded (and I am asking for confirmation), I should be using a Mustang flywheel (50oz), a mustang 10.5 inch clutch and a M5R2 4.2V6 Slave/to bearing systems.
That gets me a 157 tooth FW with correct imbalance, two bolt long-nose starter (not explorer, maybe mustang??), proper slave for the trans and correct friction and PP for the flywheel.
I remember seeing somethign about cutting the input shaft slightly shorter for teh application but I have read too much recenlty and may be confusing the situation.
The spline input shaft on my trans is 10
The 5.0 F150 (ala 1995), M5R2 is also 10 spline, 11 inch clutch
The 4.2v6 F150 (ala 2003 my year trans) is 10 spline but 11.5 inch clutch
The 1995 Mustang 5.0, 10 spline, 10.5 inch.
FW:
Mustang as above, 157T, 50 ounce
F150/5.0L as above, 164T, no imbalance specified (problem)
F-150/4.2L as above, 164T and again no imbalance (major problem)
From that it appears: Mustang FW/Clutch and V6 Slave is the ticket.
Many thank in advance.
Mike
Nonetheless:
FW:
Mike
