CoreyTilton
- Aug 20, 2015
- 9
- Massachusetts
- ranger
- Engine Size
- 302
Big project for sure. For the cowl, I can't really tell you how to repair it as I'm not a body man myself. I will recommend that you go with a cowl panel from an 89-92 Ranger. Those models used a cowl with punched holes instead of the slits that the earlier model used. They don't have near as large of a problem with trash building up in the cowl area. I don't think I've ever seen an 83-88 Ranger that didn't have the cowl drains packed with leaves and pine needles.
Thanks for the advice josh.
I'm also weighing the idea of making my own cowl now, and making it a removable piece, with no vent holes at all.
This thing has no AC or heat at all, and I'm thinking of just removing the blower motor, because I doubt it works. Other than providing air for the blower motor, is there any need for vents in the cowl?
Also, I think I concluded that the previous owner must have cut out the cowl to remove, and relocate the wiper motor. If you look at the pictures of the cowl I took, there is a whole leading to the cab that I think is where the wiper motor should be (not positive) and there are some weird pieces of threaded rod welded in, and now the motor is in the engine bay.
Also the arm linking the two wipers is now I piece of adjustable threaded rod.
