Cluster swap
bobaloo
Casco, Michigan
4 Banger
Does anyone know if a stock 1994 instrument cluster without tach can be swapped out for one with a tach? Just plug and play or will I need to do some wiring ?
tinman_72
136
North Georgia
2.5 (4 Cylinder)
2.5
Factory
None
255/60R15
RoHS compliant
Direct swap. Put your speedo into the new cluster to keep your odometer correct. Also be wary of where the cluster came from. If you get one from a vehicle other than a '93 or '94 it may bolt right in and the wires will plug in but the pinout is different.
bobaloo
Casco, Michigan
4 Banger
Thanks!
That's what I needed to know!
Thanks
