Changing oil
HenryMac
382
Central Colorado
2019, '31, '27
Ranger, A & T
2.3 Turbo, 350, 5.0 HO
Stock, about a foot, about a foot
LT 265/65 R17, P285/70R15 & P195/65R15, 820-15 & 500-15
No. Seems kind of dumb to have to remove a rubber flap with clips that break to get to the filter though.
I haven't broken any of the clips. All it takes is a phillips head screw driver that you turn by hand, and a small amount of patience. I did have to apply a bit of pressure under the mushroom head of one of the fittings last time with a flat bladed screw driver, while turning the screw with the phillips head. No special tools are needed at all.
The internet is filled with people talking smack about things they have no experience with. Don't be one of those people. It helps nobody.
Since I have to work on ramps, the oil runs down the frame, aft. I'm not sure if the trough is working as it is supposed to in that configuration. It might work better if you have a lift or a maintenance pit. It's not that big of a deal to clean up and I figure the residue rusts proof that area, I don't think that it's that big of a deal beyond not always properly guessing where the oil is going to spill out.
Hmm. That sucks. I'll bet you could slip some sort of tube, maybe a short section of garden hose, over the end of the trough to direct the flow into your drain pan?
sgtsandman
Aircraft Fuel Tank Diver
U.S. Military - Active
Ham Radio Operator
TRS 25th Anniversary
12,789
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
I could give 'er a try and see what happens.
JohnnyO
Moderator Emeritus
Forum Staff - Retired
2,868
Pittsburgh, PA
2.3 EcoBoost
1.5"
My first Ranger was a 99 3.0 that literally had a funnel bolted to the block under the filter with a hose that tucked up over the axle when you weren’t using it.
Dirtman
13,329
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
Oil is slippery.
Robertmangrum.rm
Wannabe Overlander
1,640
Tennessee
2.3 EcoBoost
2.5 level kit with rear add a leaf appox. 1.5
305/70r17
Buy it, build it, and drive it like you stole it
Blmpkn
Toilet enthusiast
6,381
Southern maine
Ford Bronco
2.3 EcoBoost
2.3
2.5"
Yeah, the filter location is definitely not well thought out lol.
Not for the end consumer anyways. It's well thought out for ford though.. gets more people to bring it to the dealer to have it changed.
The filter location on the 2.3 duratec is infinitely better.
ericbphoto
Overlander in development
16,741
Wellford, SC
3.0L
6"
I bet the guys at the dealer Curse those cover fasteners. Wastes their time. Most of them get paid by how many work orders they complete in a day.
85_Ranger4x4
17,972
SW Iowa
In regard to the T6 vs the US version... major differences between the two, including a completely different frame, bumpers and body panels. The US Ranger was specifically designed for the US. It's nothing like a rebadged T6.
On the other hand it is by no means a totally new truck for the US.
It is like the T6 with a minor facelift and a major powertrain change.
People try to lump 89-92 Rangers in with the 83-88's and they have less in common between them than the 19+ NA Ranger and the T6.
I was standing 10' away from a new Ranger (that had a T6 banjo style rear axle under it) the day after the vehicle launch in Detroit when the Ranger team was saying that trying to distance the NA Ranger from the T6 to us.
All new frame... different frame ends to mount a steel bumper, maybe tweaks for US crash testing.
Retuned Suspension... easy to do, commonly done. Ranger is more of a work truck overseas so that is very understandable.
New body... different nose to fit the steel bumper, I think the aluminum hood, front fenders and tailgate are unique to the US truck also. Possible structural tweaks for US crash testing too.
Interior... same that looks like it was inspired by something out of the '0X's. My wife's '08 Edge looks very similar.
If the Ranger was truly "all new" they wouldn't be doing a total update after only 3 production years.
It is but it isn't. Ranger has a bigger (actually not sure if the other 4cyl EB's even have one) oil cooler that changes the oil filter base. So it is good for everything/everybody except the guy changing the oil.
The oil filter flap isn't a huge deal though like henry said.
sgtsandman
Ham Radio Operator
12,789
Aliquippa, PA
Ranger XLT/FX4
Pre-2008 lift/Stock
But it is close enough that some T6 stuff will fit. I saw a snorkel kit the other day being offered for the NA Ranger from a T6. I think it was ARB.
85_Ranger4x4
17,972
SW Iowa
In the land of Oz those are a factory option...
I thought they would fit the outside but I wondered how things would line up on the inside, I figured they would have to change the air filter housing. Ford often can't help themselves that way...
HenryMac
382
Central Colorado
2019, '31, '27
Ranger, A & T
"The frame rails were redesigned to be fully boxed, enabling the Ranger to haul up to 1,860 lbs in SuperCab 4x2 guise and tow up to 7,500 lbs regardless of the cab or drivetrain configuration."
"The US didn't get the fourth-generation Ranger at the same time as the rest of the world because Ford knew the truck needed to be improved for the US market. As such, its launch was delayed as the chassis was developed further to increase payload and towing capacities."
2019 Ford Ranger
85_Ranger4x4
17,972
SW Iowa
2019 Ford Ranger
The US didn't get the fourth gen Ranger because Ford stated many times they felt it was too close in size and capability to the F-150.
The T6 has a fully boxed frame and is actually rated to tow more than the US Ranger. Their stupid (beyond stupid) statement in 2011 was if you want MPG get a Focus, if you want a light duty truck get a base V6 F-150. There is no need for a Ranger anymore. They beat that drum for years.
Here is a 2012-16 fully boxed T6 chassis for sale in South Africa:
Tow/payload ratings for the T6 in the UK:
3500kg = 7716lbs towing. '19+ has up to 1140kg/2513lbs payload.
Like the first time around it wasn't until the Tacoma and Colorado saw a resurgence in interest that Ford decided to get back into the pool. The T6 came out in 2011, the same year the Ranger died in NA. It was faceifted in 2015. It does not take 9 years to "improve" a vehicle to get it into a different market... unless you want it to.
Roert42
5,030
Kintersville, PA
Ranger XLT
4.0 SOHC
HenryMac
382
Central Colorado
2019, '31, '27
Ranger, A & T
Very interesting, thanks for posting this.
sgtsandman
Ham Radio Operator
12,789
Aliquippa, PA
Ranger XLT/FX4
Pre-2008 lift/Stock
Ford wanted to prop up their numbers on the F-150, their pride and joy, and the Ranger sales were declining. Supposedly enough that what money they were making was drying up. That seemed to work for a while until the market changed.
When they brought back the Ranger, their car sales were drying up. So, now they are focused on trucks and SUVs with vans in the mix.
It all comes down to money and the market. What are most of their customers buying and where are we starting to lose money?
