CEL Code 214
94b2300ranger
California
Mazda
2.3l is out! 4.0l is in!!!
214 (M) Error in Cylinder ID (CID) circuit or signal - Ignition Systems
only code that im getting on my reader, a little confused by it. Engine seems to run fine, just have the CEL on.
Anyone else run into this and find a solution?
94b2300ranger
California
Mazda
So after talking with the Mechanic shop by my shop, he says a lot of the time it's the Camshaft position sensor. Disconnected it and didn't have any change, so i determined it fit to replace it. I don't have a problem replacing parts on this as i did a motor swap and didn't know the condition of any of the sensor's/wear items. Well turns out I have a synchronizer and not a sensor. Not a problem, until i looked at a replacement part. You have to buy the whole assembly! Ranging from $175 from Rockauto, to $260 from Napa.
Why did Ford think it was a good idea to use a synchronizer for a few years , then switch to a sensor which is replaceable for a fraction of the cost?
Either way I was able to find a brand new assembly from a shop for $100 a few hours away from me.
94b2300ranger
California
Mazda
Replaced the sensor, fired it up and CEL never came back on!!!!:yahoo::headbang:
Good feeling now that the CEL is off, now i can attempt at getting it reffed.
8,371
Glad you got it fixed.
2001 4.0l SOHC engines had sensor on drivers side valve cover, no timing setup, just plug 'n play
The 4.0l OHV, 1990-2000, all had the synchro with sensor on the top, but as far as I know you could replace just the sensor on the top of the synchro.
Only Calif. 4.0l OHVs had the Cam Sensors thru 1994, in 1995 and up all 4.0l OHVs had them.
Generally speaking the synchro towers would wear out(bushings) so replacing the whole unit is prudent, but often not required
94b2300ranger
California
Mazda
Thanks for the info Ron!
Yea, mine is a Calif. 4.0L. I just went ahead and changed out the sensor. Holding on to the synchro if ever needed in the future.
