(CCG Doubler) D20 + BW1354 -> Build thread
patov6
July 2007 TOTM Winner!
Santiago, Chile, Southamerica
Hello friends, I´am Victor Silva (Vicho), builder of the PatoV6`s BW/D20 doubler. This idea was born to address Pato`s concern to achieve a higher Crawl Ratio in his Ranger, but with the idea of changing as little as possible in the rest of the truck (didn’t happen like that…). So, looking into the options, we decided that the best option was to use a Dana 20 Early Bronco transfer case, because of its ruggedness, size and configuration ideal for the Ranger. And opening the the possibility in the future to go into twin stick (…still does not occur, until Pato learns the rest of the combinations… hehe). So we found a D20 in a very good general state and began the task. To keep the length of the package, we chose to use the front half of the case of the BW and make a plate separator that bolted in both cases, so using the same shaft entrance to the D20 and making accommodations for the entrance of the bearing D20. We manufactured the guide and support bearing resemblance to the original set of EB too, once ready for this and taking cases coupled came the task that was more complicated…turning the electric drive of the BW drive to a mechanic. Unable to find another Non Electric donor, we had to produce the elements needed to trigger the whole reducer. For that, we manufacture a shaft that would be able to move the fork. After a couple of tests, this proved that it worked perfectly. So we drilled the case for getting into the shaft, and step down onto the pin and spring that allows it to be in the hi & low position, so we get two boxes work mechanically. Then, we reassembled the whole body into the truck , adjusted the driveshaft and installed the levers. The new transfer cases got just 2" more original length which allows them to be installed without changing any other element as fuel tank, brakes lines, etc…, the result was very good, achieving a dramatic increase in the benefits of the Ranger, and best of all, leaving the minimum alterations onboard.
sweetsride
Terrace B.C.
2.9l
Good right up except for one question for you, did you use the stock shaft from the BW case and did it go stright into the D20 case with no mods?? or did you make a new "stub" shaft to combind the 2??
More info on that you be great!!
Thanks
Kris
Jim Oaks
Just some guy with a website
Administrator
Founder / Site Owner
Supporting Vendor
TRS 25th Anniversary
8,789
Nocona, Texas
4.0 / 2.3 Ecoboost
6-inches
33x12.50x15
Pato, where did this shaft come from?
Jim Oaks
Administrator
Supporting Vendor
8,789
Nocona, Texas
4.0 / 2.3 Ecoboost
6-inches
33x12.50x15
Why didn't you use the 'electric' part of the BW case?
Vicho
Chillan,Chile
Toyota
Hi , This shaft was made welding the outputshaft of the BW and the input shaft of the D20.
Vicho
Chillan,Chile
Toyota
Because the electric system is installed at the BW rear...using the D20 in this position, we can´t use it, is a better choice to use a non electric BW case to this doubler .
Vicho
Chillan,Chile
Toyota
Thanks
Kris
:icon_thumby:
Vicho
Chillan,Chile
Toyota
a couple of pics installed.
[/URL][/IMG]
[/URL][/IMG]
[/URL][/IMG]
4x4junkie
584
So. Calif (SFV)
Bronco II
2.9L V6
35x12.50R15
I've been waiting for this post for a long time now. Glad to see it. :)
How did you seal the shift lever shaft where it comes through the BW case so the oil doesn't leak out?
4x4RangerGuy
5
Newton Highlands, MA
Subaru
2.0
Me parece excelente Vicho, hace un buen trabajo. Cuánto tiempo duró este proyecto? Los videos son buenos también.
patov6
El proyecto de la Doubler tomo algo de 1 mes. El trabajo de Victor (Vicho) es excelente, en Chile es muy conocido. Gracias!
The Doubler proyect took close to 1 month. Victor´s work is excellent, in Chile he has a very good reputation.Thanks!
PatoV6
