sorry I ment the component/sensor/lamp each pin runs. I'm looking for pin numbers for MIL, fuel pump, low oil light, battery light, low brake fluid signal wire, ignition run wire, and ignition coil signal wire
Tach signal (I assume what you mean by "ignition coil signal"), pin 12. All wires needed to trigger the coil remain in the engine bay and do not come through C105 into the cabin.
Run, pin 53
Fuel pump circuits do not pass through C105. The fuel pump relay powers up off the PCM relay, runs power to the inertia switch, and back to the pump. Those wires pass through the firewall near the inertia switch on the passenger side of the vehicle.
my goal is to pin point all the important stuff and splice wires to make a jumper harness. I'm trying to convert the 2.3 dash harness to a V8 harness out of a mustang. If anyone else have better Ideas Let me know
For
a small yearly donation, you can support this forum and receive a 'Supporting
Member' banner, or become a 'Supporting Vendor' and promote your products here.
Click the banner to find out how.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
