Can 89 2.9 engine bolt into an 87 bii?
whitebroncoii87
11354
bronco ii
rang
Hi, I want to pick up an 89 2.9 engine from an ad, just want to confirm will it bolt to my 87 bronco ii without any adaptors? Thank you!
redhurricane
Westminster, Colorado
2.3
If the 87 had either the 2.8 or 2.9L V6, yes. Same Cologne bell housing pattern.
whitebroncoii87
11354
bronco ii
rang
Ok, thanks!
Is the lower engine block the same from 87 thru 89?
redhurricane
2.3
ALL 2.8 and 2.9L V6 are the Cologne bolt pattern. Same engine.
There are only two parts on your engine that are different between the 87 and 89 engine. The upper intake, and the driver's exhaust manifold. Those changed because the EGR system was deleted in 88. The 89 will lack a knock sensor, which can just be transferred from the older engine.
Those are the only production changed that you need to be worried about.
